Xiaomi Mi Max
Bobby Goh
Export sets is risk seller flash modified rom. Now only 32gb got global rom. 64 and 128gb only China rom. If u get export global rom 32gb it is exactly same as local set but wo warranty. Warranty to me is redundant. My past few phones all export except note3 all no problem after 1 year
Correction. Now, 64 GB and 128 GB has official global ROM. I'm using the official global ROM on my 64 GB
Sent from Yugoslavia using GAGT
Bobby Goh
Well... i only use miflash beta for my method... some say can use the stable miflash... so... not sure since i no try the stable miflash....
But.... it can be many problems arise to that... maybe he never use the vol+, vol- and power button mode (black screen) and use the normal fastboot mode........ maybe cable is faulty/dirty..... maybe usb port is sot/dirty....
I followed DragonGuy method (someone posted 2-3 pages ago) and am able to flash the global ROM on my 64gb.
spark7
We most likely to recommend you mi max over it since it is snapdragon based..... bigger battery.... bigger screen...
But then..... wait u get mi max le.... you probably gonna u-turn/prata like our infamous bro due to screen big... cannot fit into pants... *puns intended*
Just like bro Oinkize says, happy can le....
slot behind pocket of the jean also cannot go in?
kandinsky
Surely this depends on the size/cut of your jeans and how fitting you wear them? You go and measure the depth of your back pocket for a gauge I guess.
E.g. Most of my jeans back pocket depth only about 4.5-5", around 1.6-2" will stick out. If your jeans are fitted you won't be able to sit down. Sure bend in half :s13:
Compact7
Anyone who buy this phone must prepare to accept that you may need to handcarry it or put into bag due to its size. I tried so far it can fit my jean front pocket when I standing. Sit down need to take out unless got plenty of leg room..
Compact7
To all 64GB who was in previous 8.0.3.0.MBDCNDG rom, may I ask after you updated to global rom, the play store is automatically installed or need do it yourself?
P/S: I am deciding to get 64gb one..so pardon if this oredi mentions time in previous thread...
thks
azbyza
No, I easily put it in my pants pocket.
Normal gents pockets are very roomy.
Oinkize
thks
Global rom means all gapps are preloaded...
charleslee
Order received (after a month) but dunno why they want to use such a big styrofoam box - and strange thing is, they have bubblewraps alright, but they did not wrap the cover with it. Instead, they just stuffed the cover into the box and placed the bubblewraps on top of it..
