Xiaomi Mi Max
kelvinti
Is still good for me at 40 to 50% level. May be you can try another headphone. I am using headphone from my old Samsung S4. Otherwise, you may have a lemon set.
OK. Let me try with another headphone later and report back.
I'm using LG quad beat 2 headphone from my previous LG phone.
azbyza
Welcome bro!
It will not disappoint. Huge screen is the killer for entertainment purposes or almost anything you do. Typing is easier too with big keyboard. :)
That's why I come back to Mi Max for the 3rd time...just can't imagine that. Lol..
I can miracast from Mi Max 6.44in screen to my 65in tv screen for 100x the screen area hehe.
Plastick
Wah. Sianz..
Cannot take the bloody low volume. I though it should be fixed by now..
WTF is the global miui team doing.. :(
Going to flash back to pre 7.5..
pls sic if any links for pre-7.5 global? i see there's only 7.3.1.4 which is the china rom. cant stand the volume too
virus2977
Just hoot on this max case. The case jin tough and heavy....lol
Sent from Samsung SM-N9005 using GAGT
kelvinti
I'm still searching for it.
Gosh! :o I should not have deleted my Global 7.3 versions of Fastboot ROM months back! :(
Oinkize
Quick use your Infinity time stone and turn back Time...
vodka_water
was trying to factory reset my xiaomi max bought from smartcell but it ask me to enter a password for a unknown account which was input by smartcell i suppose. what should i do? pls advice.
went to smartcell & they are kind enough to proceed with flashing my xiaomi max back to miui 7 but when setting up, the phone still require me to enter the password of the mi account that was login previously. The problem is that the account was not mine. anybody can help here? TIA.
cscs3
You get the phone 2nd hand? This remind other before purchase, ask the owner to de-register phone from his account.
bbcccc
its 1st hand, is directly from smartcell. didnt know xiaomi got such problem.:s22:
i kana this prob too
was on china stable rom back then, flashed to global stable
upon setting up, kip asking me to key back old id
no matter how i set up, it kip asking the same id
do until tulan, jus ignore n press next or something liek tt
can setup le . . .
vodka_water
can setup le . . .
mine max gave me a unknown ID then ask me to enter PW. 1st time use phone until so headache.:(
kelvinti
Can you all create a new ID instead of signing in to that unknown ID when prompted?
Warlock86
I just collected my Mi Max. It comes with global Rom 7.5 and three pin plug. So far so good.
kelvinti
Just stay at 7.5. Don't update to 8 for the time being.
8 has this low volume issue that has yet to be fixed if audio is important to you.
Warlock86
I got this Mi Max for my mother so audio should be important for her. I will ask her not to update to the latest firmware. Thanks for the thumbs up.
kelvinti
sorry ah, but does that apply to 3S also?:s11:
or MI Max only
That I'm not very sure but it seems to be a firmware issue affecting a number of xiaomi models as per what I read and understood.
Other Xiaomi gurus might want to help here. :)
