Xiaomi Mi Max
Oinkize
default china rom comes with it
some tempered rom doesn't hv it
download manually if it's nt there...
The problem is if install from play store it only has the function to send out data and not receive.
Unless there is an apk that does receiving and sending?
Oinkize
Will but but think I'll wait till global rom is released and hopefully shops will sell unit with it so no need to DIY
I am very tempted to get the 64gb now. Just worried that there will not be a global ROM for 64gb...
gonnie
hihi,
very sad day for me..i dropped my mi max and the entire screen cracked..anyone knows any where got mi max screen replacement service? thanks in advance le~
Starbutt
hihi,
I replaced mine mi4i screen at xiaomi service center before for about $150. They are at Central mall. I know I could have top up a bit more to.get a new phone but problem was I couldn't retrieved the data at all as the touch screen was jammed after the glass cracked.
Sent from Xiaomi MI 4I using GAGT
pilico
hihi,
I would recommend you to fix it yourself. Buy parts from aliexpress, should cost you less than 50 sgd.
cueball1981
Just got my mi max, seller already got it to global rom and with g Apps. Does that meant that it is unlock. Interest in flashing the miui8 for the clone app. How do I get the unofficial global version?
Audiology93
Where did you get your from? I just placed an order from qoo10 seller ziming global(bought a few phones from them before).
kelvinti
The Mi Max SD bootloader doesn't really need to be unlocked to be able to flash global rom, right?
There is this miflash tool method for locked bootloader fastboot flash right?
gonnie
pwah, technical stuff, i am quite un sure, even screen protector i keep failing le haha, thanks thanks!
Nakedtoes
Redmi note 3 build quality should be n better so far seen 3 cases of cracked screen for max and 1 for note 3
