Xiaomi Mi Note
Just Me
Regarding the quick charge, I think the wall charger provided is quick charge compatible, coz I noticed the charger output listed 3 settings, 5V 2A/ 9V 1.2A/ 12V 1A
The usb cable is also thicker than normal with a electric symbol at the end.
Nevertheless, I feel that Mi Note does charge up much faster as compared to my redmi note 4g
If the USB cable has a lightning logo, it's QC compatible
xenocide
updated from 5.7.26 to 5.7.27 to fix wakelocks and battery drain issues
so far so good. MiNote Pro only
Just Me
Anyone who also owns a mipad tried using the minote wall adapter and USB cable to charge it?
BERSERK1980
Been using it for a couple of days. This phone simply is fantastic. Built quality, slim bezels, sharp display with raised glass. Its definitely one of the best looking phone out there.
amazingone
Want to ask, whether the vibration of the Mi Note is strong, as some teardown reviews show that the vibrate motor of the Mi Note is smaller than iPhone 6's motor, which could mean Mi Note's vibration throughout the phone might be weak. :)
Sent from Xiaomi REDMI 1s using GAGT
BERSERK1980
How is the xiaomi earpiece???? Did u buy?
Am using the old gold pistons 2. Very nice pairing especially with the hi fi audio setting turned on. The onboard dac is pretty nice, on par if not better than the note 4 sq in terms of quality and volume.
Iron_Maiden
i just order the mi note. So which earpiece should i get?
JuXn5566
Sq definitely many levels above note4,Iphone6, or any other phone without HiFi. However do note need to use built in music player and turn on HiFi mode for full power HiFi sq. If use 3rd party player, it will sounds like normal phone. The HiFi on Mi note is loud enough to power full size open back headphone like Sennheiser HD600 while normal phone can't.
If you get Mi note HiFi feature, use Mi in ear will be quite wasted. Recommend you to get budget iem like vsonic VSD1/3.
Sent from Xiaomi MI NOTE LTE using GAGT
caterham7
depends on your user scenario, e.g.
1 - if using on public transport, buy in-ear monitors, to block out external sounds
2 - if using at home, buy full-size headphones, can consider open-back ones
3 - if you don't like your hair being messed up by headphone band [i.e. example 2], can try clip-on headphones; note these clip-on type, typical poor isolation, so more for use at home
4 - if using at office, can consider open ear-bud type, which look more discreet, yet are open, so you can hear when your colleague calls you [or when phonecalls come in]
