Xiaomi Mi Note
JuXn5566
is the camera quality great?
Judge yourself. Some pics I took.
Sent from Xiaomi MI NOTE LTE using GAGT
BERSERK1980
Sq definitely many levels above note4,Iphone6, or any other phone without HiFi. However do note need to use built in music player and turn on HiFi mode for full power HiFi sq. If use 3rd party player, it will sounds like normal phone. The HiFi on Mi note is loud enough to power full size open back headphone like Sennheiser HD600 while normal phone can't.
If you get Mi note HiFi feature, use Mi in ear will be quite wasted. Recommend you to get budget iem like vsonic VSD1/3.
Yes i concur. The volume is really loud and clear compared to note 4.
mun
No NFC, no Finger print reader, no heartbeat sensor, no sd slot, fast charge charger not included.
If it really comes with those features and accessories, the price wouldnt be $569 anymore =:p
Milo-Dino
hmm anyone moved from mi4i to mi note?
I can't load the backup file from mi4i to the new note... is it because one is lollipop and note is kitkat?
tckrto
I have both phone. I used mi cloud to port my important stuff over. The rest like apps just login Google account and install back the commonly used apps.
caterham7
Suggest you post in mi community, so that xiaomi staff and volunteers can assist
c.mi.com/sg
Milo-Dino
Oh so u still manually reinstall the apps.
Cosz if port, all WhatsApp conversation and other stuff like axs records all will still be intact
Sent from PCW using GAGT
