Xiaomi MiTV2 help
Kopi Gao
all done myself.
i working in china.
u can also purchase and have it shipped to a china forwarder. plenty on TB
Thanks Bro badsector. Since you work in China, can I ask did you consider other Chinese brands like TCL, Hisense, Skyworth, LeTV, Lenovo, Changhong etc. during your purchase? Thanks. :)
badsector
think they are all almost the same. it's just the design and the panel manufacturer to consider. xiaomi does looks better to me.
i1magic
if i buy mi tv but i dont want to use the woofer and the sound bar does the tv itself has built in speaker which produce sound.. i dont think i hv enough space to put speaker and sound bar
Yes. The TV has speakers.
produde1999
I agree with you. Think they provide 1mth warranty, 1 to 1. Just top up $25 and they'll install YouTube for you.
But I am not sure whether to pay $150 for the soundbar + sub woofer or not. Can anybody offer some advice? Whether to get or not? Worth it or not.
Imo its not worth getting the soundbar + subwoofer. I mean like seriously. Since when serious sound is just a soundbar... Need least stereo 2.0 . It's just pathetic to see one soundbar there.
i1magic
I am wondering this also. That's why I wanna ask for review here.
Actually from the review on the video, the sound bar & sub woofer is quite worth getting.
produde1999
The soundbar and subwoofer does have good audio quality. I trust xiaomi. But even then. Its a soundbar... U have a 2ears. So least need 2 speakers. The soundbar is only worth if u plan to add speakers with it to make it surround sound theatre or smth
Sent from produde1999 using GAGT
kun1he2
LG just died... so thinking maybe should just buy best bang for buck TVs instead...
Looks like MiTV2 might just fit the bill... haha... wifey may not agree though... hmm...
liverpoolz
any good forwarder to reccomend.?
looking to buy direct ftom taoball or tmall...toobad cannot use 4px.
i1magic
So I guess it depends on what a person wants.
For some people, anything less than 7.1 is a compromise. But for some, got sound can already.
i1magic
I experienced what you going thru now in Jan 2015. Right after 3yrs warranty, my LG 42LV5500 died. I bought a cheap SkyWorth 42" LED TV @ $430 then. Because I feel that I paid about $1K for the LG TV but it still died on me right after 3yrs.
Expensive stuffs doesn't guarantee that it'll last. It is like what my friend says "Heng suay". So might as well "heng suay" with cheaper ones.
Just tell your wife that a 4K 55" from LG / Samsung will cost about $3.5K range. Mi TV2 is about $1.3K. If the Mi TV2 can last 1yr, already "so-called" breakeven. 2yrs good. If last 3yrs or more, it is super bonus.
I also planned to get the Mi TV2. I tried finding spare parts on Aliexpress for Mi TV2 and seems to be quite alot. I guess also that spare parts for Mi TV2 should be easier to find than for LG / Samsung model.
But now I am waiting for the T-con board for my LG 42LV5500 to reach me. Will put in to test, if working, ho say. If not, sian liao .... must spend $$ again.
kun1he2
Yah, now the suay part is that LG no longer produces the spare parts for my TV which is barely 4 years old! Planned obsolescence indeed! Got no choice but to buy new TV - but will I still buy LG?
Actually, how do you know for certain that it is the T-con board that failed?
So, for MiTV2, have you shortlisted any particular Qoo10 seller? Pls PM me if not good to post here.
badsector
mitv if got any parts faulty can be very troublesome ......
i wouldn't even bother repair if it breakdown.
i've got 2 tvholic ..think they watch 12hrs daily. hopes the mitv lasts...
seems like many here go for good sound system. won't ur neighbours complains? my living quite small also. no point right?
i1magic
Precisely, all the more reason we don't buy expensive TV.
I went through some YouTube video and conclude that it could be the T-con board that is spoilt. Another main reason is because the exact T-con board is available for sale on Aliexpress for SGD$22 (with shipping).
So just buy it to try. If cannot, then will have to spend $$ buy new one already.
There are a few seller on Qoo10. But whether good or not, I can't comment liao.
