Xiaomi MiTV2 help
sEnG55
Anyone know how to get into the advance setting for wifi to configure VPN?
I used the provider VPN app on the tv but it cannot get me sign in, seems to be missing something.
kaitozaki
MITV 2 55" unable to install apk
hi guys i have xiaomi MITV 2 55" problem
i factory reset and now i cannot do the following,
1. boot into system 2
2. unable to install apk
3. unable to do OTA update (stuck on 1.2.0)
i need to manually install firmware from USB, does anyone have or can repack to zip file for me?
all apps will stop and will not install anything, so stuck at stock mitv android.
i cannot upload pictures yet
i have contacted xiaomi but do not want to give the firmware, i'm only able to find 49" and 47" firmware but no 55"...
from xiaomi singapore -
Welcome to Xiaomi Customer Support!
I would like to inform you that we do not have any firmware for Mi TV as it is not yet launched in Singapore. If you are sending mail from outside the Singapore then kindly contact with your respective seller or with your regional support and if you are sending mail from Singapore only then would like to inform you that you need to contact with the seller only. Mi TV is not yet launched so we do not have technical update about the same.
Should you have any further queries, feel free to write back to us. We'll be glad to assist you further.
Thank You for being a valued customer. Have a great day ahead.
Best Regards,
Shubham
from xiaomi china -
亲爱的用户,感谢您对小米的支持。但是目前针对您的需求,我们无法提供新加坡的固件升级包。建议您联系卖家协调处理,如果有任何问题请后续及时联系客服,非常感谢~
produde1999
Best Regards,
Shubham
from xiaomi china -
It is expected the customer service wont help u with anything.
Forget the firmware. Does the hdmi still works? U may wanna buy tv box and call it a day.
kaitozaki
how i wish, but everytime i reboot or you can say switch off the tv and on it, it will prompt all the system apps which force closed...and it's an infinite of prompt...then i need to reset and start over ...anymore ideas...i remembered booting into android system recovery...not mitv recovery...maybe from there i can save my backup and edit the zip and restore...but i just seem to get in that menu...
kaitozaki
Already contacted...the seller is from passiongadgets...again no help also...keep saying will ask his tech and get back to me...
But still no reply
Devilsire
PG staffs have limited knowledge on mitv. (Previously I enquired about the 2 types of 3D glasses for mitv2 & they were not able to answer).
Anyway, try again with Xiaomi China support. Simply emphasise your tv model & that it's from China xiaomi, requiring manual firmware. Dont confuse them with any mention of Singapore as they will cease any support.
kaitozaki
i did alot of times, i changed story, thats when they told me they can't send, but the thing is why can't they just send a zip file??? is it that hard? i wonder how the 47" and 49" firmware is all over the web...but the 55" is not...but even when i asked xiaomi china they asked me for the "number"...i'm guessing its a warranty number maybe? cause i google translate the text they sent so i don't really know what they are asking...
but no matter what they still won't send...so my hope is to wait till someone repack the zip for me...
produde1999
It'll be better to post thread in miui forum. They'll help you better there.
kaitozaki
also did that...but they are more to mibox now...or mitv 3 and 3s but no firmware this is the last place i haven't tried...although there is a place to buy the motherboard...cost is about USD56+...will try to ask them if they have the firmware...
gnixer
you try to search in chinese perhaps you will find more result otherwise see any forumers got the old model and able to extract the firmware for you.
another way is you go to youtube search the downgrade of mitv firmware then ask whether the guy has the firmware for you.
last bet is you whack the firmware in regardless of the size of the tv. technically speaking the firmware should be universal across the same model except for the size.
kaitozaki
also tried hahahaha...baidu.com... i translate the and copied whatever text i need in many ways...
like you said whack any firmware...could be my last choice...but i heard it will brick the tv...
just now i open up my tv...to see the motherboard - DKTV-E-55-928-AE-20150129
same with the 48" board...so 49" and 47" there is a firmware could be the same and 55 and 48 could be the same... problem is there is also no 48" firmware...
again would try to use 49" firmware...if still fail then i will just order a new board...
can go to englishtaobao dot net
they also sell the screen i think...
launm88
49" use LG panel.. 55" use Samaung panel..
most likely firmware different...
i1magic
Best Regards,
Shubham
from xiaomi china -
There is currently, no Singapore version of firmware for Mi TV 2, only China version. So did you try asking for the China firmware for Mi TV 2 55"?
kaitozaki
thanks will wait...anyway i found out how to unlock adb debug from xiaomi settings...the older version have adb in the menu...but now dont have...then now i have unlock it...will update again as im trying to sideload...
there is still hope...
kaitozaki
GUYS...i fixed my tv!!!...@pspeter if possible just send me the firmware...just incase...
i will be writing a guide on everything i did and what you should not do...thanks guys....
it was a long 2months without a tv...
