It come in China pins, just need to use a travel adaptor to convert. The input voltage is same in both China and SingaporeMay I know if the power supply will be different? Do they use the same 3 pin plug as us? If it is different will there be issues when we use it on our power socket?
You need the Xiaomi 3.5mm to SPDIF Cable, and a coaxial to toslink convertor as shown in the link:
http://www.amazon.com/Digital-Coaxial-Toslink-Optical-Converter/dp/B001622FL8
Disclaimer: I have never used these products. But on paper it should work, also verified by those who bought the convertor. Quality of sound unknown - no review on that - people were just happy that it worked.
Edit: you still need another Toslink cable to connect from the converter to your soundbar.
I uses EK Link. This TV is part of my large shipment of 1.76 cubic metres. The cost is RM550 per cubic metre. The volume of the TV and subwoofer (including the wooden crate) is 0.32 cbm, which works out to be around RM176 for the shipping. The cost of the crating is less than RM100.
ME too.. mi tv3 for my new home.. decent price for a whopping 60" in my living room. .gonna love it.
Please include me if there is a group buy to share shipping.
Question on the Xiaomi SoundBar ? How to connect to the AVR while cutting off the sound from it, meaning just the AVR sound only.
What is your purpose of connecting Mi TV3 soundbar to the HT AVR?I am very curious as to how is the soundbar connected to my HT AVR assuming that it is the Mi TV3 soundbar that with the tuner inside.
Anybody updated to 1.1.92 yet?
Yes, after checking internet resources, I concur with your findings. Other than the audio out for subwoofer, there is no other audio out port to connect to your HT.This new MiTV3 soundbar is part of the TV tuner, therefore the audio output is only one. And this one is the low freq audio output to the Xiaomi Sub which is optional.
I can't figure out how can I have it connected using my home theater system.
I don't find any audio output from the TV which is technically a UHD monitor.
Personally, I would get via those "agents" selling in Spore.
Why? Reason is because they'll have people in China to check the TV to make sure that it is ok before shipping out to Spore. Any spoilt ones, they'll do RMA in China.
When the item reaches Spore, they'll check again. Same thing, any spoilt ones will be RMA-ed.
So only those that is ok, will be arranged to be sent to customers.
If the set that you received is spoilt, then it is damn "suay" liao.
As compared to you ordering directly and do your own shipping, you may save some $$ but if the TV reaches you spoilt, the shipping charges is crazy.
Anyway, you guys weighs the cost & benefits.
Other than the 2.5 mm connection, can't find any technical info regarding the subwoofer output - whether it's the normal L +R signal, one channel low frequency output, or something else. So can't tell whether it works if connected to HT.
On checking further, found that the BlueTooth supports headphone, and audio. (http://en.miui.com/thread-173382-1-1.html)
I can't find user manual for more details.
Maybe you can explore BlueTooth Audio Adaptor/Receiver (L + R only?) further.
Quite afew in qoo10. They do have shopfronts if one prefers. Of cos, at a slight markup price for sureHmm where to find these agents??
