Xiaomi MiTV2 help
pawn_king
Qooo10 selling 1,299 with sound bar and sub woofer.
Shipping it in will cost 1.1K. without sound-bar and subwoofer.
Anyone bought from Qooo10?
Qoo one is jailbroken, how important is this? Or simple to jailbreak by ourselves?
PentiumPC
Called and text the seller from Qoo10 but no reply.
It is android, so I think it is easy to JB.
I might ask my Chinese friend to help me buy and ship over. Or spend a bit more to get a japan brand with warranty.
Saw Panasonic 4K at 1.7K+.. will go check do more research next week.
alvinaloy
I just bought mine from a seller on Qoo10. Took only 3 days to deliver. They helped me to root and set to English along with installing quite a number of apps; some are their apps, need subscription and username to login, some are apps cracked by them.
However, I'm encountering some issue where my apps intermittently exit. Not sure what is wrong. I'm running Synology NAS at home and installed DS Video into the TV and stream from there. MX Player was installed and used to play the videos. However, after running for like 3-5 minutes, the video would exit. Any ideas why?
jimbo73
Hi, is the seller based in Sg? is this link the one that u bought? tks
Qoo10 - **LOCAL SELLER**
blazingfield
I got it through a fellow Carouseller. He's friendly & prompt in responding. He doesn't sell this specifically. He's just bringing it in together with his goods for his other business. You can get it through Taobao & use 65daigou to ship it in for you too.
Bear in mind that all this is at your own risk though. He only guarantees for the shipping for no crack or damaged panel on the TV. Good Luck !
65daigou got a service where u pay extra for them to inspect your goods before sending to sg. if the goods are found damaged, they will push back to seller for you (this is only applicable if u use their buy for me service) if the goods are in good condition, they will take photo and send to you as proof to show that it is i n good condition when it was at china warehouse
angeltst
I bought mine from q10 too, very friendly and supportive seller. even have good after sales support, paid 1299, worth every bit of my money.
Btw hor, any bro here used around few hours can feel the heat at the bottom of tv? Is it common?
badsector
I wish to know whether china airport/airline has issues with this odd size luggage.
Has anyone successfully hand carry 1 back yourself?
thanks.
cscs3
Standard DvB T2. Tuner.
LG new 2015 model 700T @ $1049. 42in. 4K Tv with smart remote control. 3 years warranty. New 4 color led/lcd display. (3 usual color plus additional white).
Suggest after purchased. Pay a little more to get some small Andriod external player attached to tv via hdmi port. Many brand including Xiaomi to choose from. Get your main TV itself out from any potential OS bugs, especially Muiu.
mingfreakrsx
Introducing 40" Mi TV 2 ~
[Launch] Mi TV 2: 40-inch Full HD LED Smart TV - Mi Community
Sent from my Mi device using GAGT
cscs3
Do you still believe in the word upgradable to Andriod 5 from Xiaomi?
Also 5000 to 1 seem low spec in todays standard.
kawan
bro,
care to share where to source for this?
I found courts online 49UB700T at $1699
thanks in advance
cscs3
bro,
thanks in advance
Seem you are talking about 49in one. The price I mention is 42in. Price from Gain City.
manchow1984
Bought this TV via official XiaoMi CN Taobao store.
Can use SG credit card to pay
Now waiting for them to ship the TV over 65daigou warehouse.
How much shipping fee you need to pay to 65daigou? Do u request them to add on any extra packages to prevent damage to the TV? So total for the TV cost how much? Very interested to buy one too.
mingfreakrsx
how come the new version like a step backward? 40" only and no sound bar and woofer, price rmb1999 also so so only if you factor in freight cost.
Still prefers the 49 inch version 1... seems better.
I think the main aim of Xiaomi is to have a smaller and a bigger Mi TV 2 variants(which explains why the 40-inch is still branded as Mi TV 2) to suit different needs. :)
manchow1984
I aint sure. Item has not arrive 65daigou warehouse yet.
According to xiaomi website. The TV with its package weight about 18kg.
Add in wooden crate should be about 30kg?
U asking 65daigou put extra wooden crate for your tv? how much they charge you? Mind to share how many Kgs after it reached 65daigou warehouse?
