Xiaomi MiTV2 help
lineasy2
Bro, the MITV2S is DVBT. So can i receive all the other HD channels in Singapore? Or i still have to buy a separate Digital Box?
Thanks in advance.
lineasy2
so avg how much for a MiTV3 55" ship back from TB?
Hi Quest,
I just bought one MITV2S. I bought it thru Ezbuy SG. You can download the ezbuy app from play store then register. You go to the surf optiom below tab. You can purchase it thru Tmall or taobao. Go under "Buy for me"
The TV for 2S 48 inche was RMB3099 plus my shipping fee, insurance and GST and wooden box protection is about SG$150. It takes about 15 days by Sea.
lineasy2
for Xiaomi TV 3s can we buy our preferred wall mount from Giant / Gain City and install? Or die die must also buy from Tmall xiaomi tv seller?
I suggest you buy from China Tmall or taobao as the local ones are not going to let u mount the TV.
daylight
And the best is, you can even use this app to control the volume of the soundbar and subwoofer with the phone while it is used by the TV :)
No need to go to TV settings anymore if the subwoofer is too loud or not loud enough :) :)
where to buy this xiaomi soundbar ?
kazuki666
Anyone actually bought the Xiaomi tv directly from tmall official store before? Shipping cost around how much?
Any problems using it on our voltage and ampere power difference?
Any problems receiving Singapore local channels? This one important, else my mum will frown if she can't watch her regular dosage of tw and Korean drama on our local channels... :p
I am thinking to get the 43" for my living room.
Thanks guys.
Sent from Xiaomi REDMI NOTE 2 using GAGT
i1magic
bro, did you compared this with the mitv 2 sound bar? or vs HTl 9100 sound bar?
Don't have. How to test? Don't even have the unit.
But I personally like the Mi TV 2 soundbar and subwoofer. When I play with volume at 60%, whole living room is vibrating liao. Damn shiok!
i1magic
I not sure if i am on the right thread... i have a mibox from china and i connect to my samsung bn68 TV with only 1 HDMI input, it doesnt gives any signal... what can i do?
Sent from Samsung SM-N920I using GAGT
Not really. But if you didn't use the HDMI for very long, try plug in and out the HDMI cable to try again. If you got notebook, try and see whether can you push the display from notebook to the TV.
If can, then check the mibox and try it with another TV / monitor.
