Why not try with a HDMI extension with your mi cable...
http://www.walmart.com/c/kp/hdmi-extension-cables
can do also but if mi port cable spolit....den gg le?
Where and how you order from?
Daigou65 prime service lor
Oic. From what I heard, they only covers the items for physical damage. Means that if the item physically is ok but cannot turned on, they don't covers.
Did anybody bought any electronic stuffs which is DOA and successfully made a claim?
Is a risk which have to take lor
Xiaomi has obtained the broadcasting rights of Euro 2016 for their Mi TV ~
[/URL]
My Xiaomi TV 2s 48 is stuck at the Mi boot logo. I tried the home + menu and swiping left and right to access the recovery mode. Both don't work.
Is there any other way to fix this?
Is your remote controller IR or BT?
Try this :
https://xiaomi.eu/community/threads/mitv-2-rooted.24767/page-5
Let us know if it works for you.
My controller is the IR version. (I think, since there is no bluetooth icon underneath it).
The site you gave is one of few answers I tried. (The swipe left and right method). It didn't work for me.
New update.
After 20 times of random patterns...
It works now. My remote is indeed the IR version. I had to turn on my tv using the power button under the tv and use Home + Menu on my remote.
I suppose the 2s version needs to do this instead.
Great! Glad that you managed to find a way. So did you managed to power ON your Mi TV 2S yet?
Yup, it's working properly now. It's using the system2 to boot. Now to find a way to repair system1.
Hi guys!
im a new happy mi tv 3 owner!
would like to ask if there any options for us to tweak the brightness/contrast or any of the tv settings?
is there any 'equalizer' functions for the sound bar?
or do i have to root it to get those options?
I too have placed order for the 55" MiTV 3....keep my finger cross
can't find the link for the Prime order. how do you ordered thru ezbuy?
Wow .. great. How did you buy the TV and how much and how many inch? 70"?
Yes. Try pressing the menu key and see whether you can adjust from there.
The Equalizer is an app. There should be a QR code on the soundbar, scan to download the app.
