Xiaomi Redmi Note 13 series
GoodBetterBest
Is it reasonable to compare Redmi Note with Poco ? I saw this recently launched Redmi Note 13 5G ( no pro ) and another recently launched Poco 6F ( no pro ). I tried to do some comparision. I think HW is more obvious like different CPUs, fingerprint scanners, sdcard etc. But I find it hard to compare the picture quality. There is a YouTube video comparing these 2 but they only compare the specs.
So I wonder how the pic quality compares between these 2 phone, if anyone has tried and can give some comment, I would really appreciate it.
Thanks a lot.
caterham7
Thanks a lot.
f6 camera-specific review here
if u are considering camera as a priority, recommend to check out pixel 7a
around $450 during promo, comparable to poco f6 pricing
GoodBetterBest
That's the thing. I don't take many pics but when I do, I think the pic is not that good. So I wonder if I should spend more on potentially taking photos when travelling using a Poco 6f or just get a cheaper RM note 13 5G.
So was hoping some comparision that can help me make up my mind. One thing I found out about Poco 6F was the night mode is good.
8-lane
I'm surprised that a Poco model can be quite good in taking photos because they are good for gaming (except the low-end models think) but not known to take good photos...
carboy00
Thanks a lot.
Poco is really designed for performance at lower prices, not for cameras for sure.
I do feel current Redmi Note cameras are better than Poco ones, although you will give up some performance for the better cameras.
Read HWZ Forum Rules via Xiaomi 13T
rerear
13 pro or 13 pro+ better for the money? Can't figure out the difference. Where best to get, either new or refurb?
caterham7
You can use gsmarena compare website to see the differences
What is your budget and usage requirements?
Value-for-money depends on what you prioritise also
Chisel
Main differences to me.
13 pro runs on snapdragon. 13 pro plus on Mediatek
13 pro charges at 67w. 13 pro plus at 120w.
13 pro uses ufs 2.2 13 pro plus at ufs 3.1
13 pro ip54 13 pro plus ip68
13 pro is flat screen. 13 pro plus is curved screen.
Caterham7 says it correctly. Value for money depends on what u priorities. You see what you can get with your budget and if you need to top up to get what u need.
To u, maybe camera is a priority so probably can read reviews which takes better pics.
alex22
Ufs31 and ip68 for me, local set pls.
I prefer slow charges usually unless in a rush which usually never happens unless i fall asleep and forget charge then morning rush plug in feed 20min while i shower, 10 more to get dressed...
Heng dun happen much
caterham7
For non gaming, reasonably good battery life and more photography centric users, would redmi note 13 pro be a better buy than a x6 or similar priced phones?
If your budget can go to $430, pixel 7a is that price after vouchers. Will be better choice if camera is priority
rerear
buying local set from Lazada Official Xiaomi shop, will be also china 2 round plugs, or SG usual 3 pin?
