Xiaomi Redmi Note 13 series
tian_yibang
Note 12 Pro got 4G & 5G version.
4G version the setup (CPU and camera sensor) is exactly the same as Note 10 Pro.
Need to know his fren use which version.
Moi guess 5G ba
since nowadays when ppl bai new fone they tend to want "futureproof" it for later usage
unless his fren state otherwise
caterham7
also using a note 10 pro here
all good but battery life starts to die off quickly o_O
is it confirm note 13 no sd card slot
supports micro sd card slot, see spec page below
"Expandable storage up to 1TB*"
https://www.mi.com/sg/product/redmi-note-13/specs
note: there are 4 variants sold in sg, pls check carefully which variant you are buying
rmn13
rmn13 5g
rmn13 pro 5g
rmn13 pro+ 5g
bladez87
Looking to buy note 13 for mom. $209 on shopee good deal?
There is also note 12 4gb+128gb for $169 but I think ram will be an issue right?
Any other better deals for entry level phones from any brands? Thanks
DesilDesil
Can look up Samsung Galaxy A15, better cpu similar price. I seeing 160-180 from reseller, but samsung phones now have no charger
Note 13 4G would be an okay budget phone but the processor is way way too outdated (Redmi note 10 is faster than 11,12,13. cut corner reuse ultra old parts lol)
bladez87
Thanks. Will explore A15 then.
But if I rmb correctly, A15 only has 4gb ram, which might be an issue.
8-lane
Poco m5s on Poco/Xiaomi official store on Laz/Shopee... got amoled screen and dual stereo speakers IIRC...
DesilDesil
From phones, Cpu for speed, Ram is for opening more apps . Xiaomi's OS however very aggressively kills background app
wwh5210
Thinking to get Note 13 Pro. Wish to check out something before my purchase:
  1. Are there still tons of ads for international version?
  2. Is the notification delay issue still exists?
  3. How frequent is their system update?
Thanks.
mosmos
High Honorary Member
Thanks.
1. Turnoff recommendations
2. Dunno, NVR experience before for any phones
3. Just received the set yesterday, dunno
Bought mine at qoo10 $322 ($399 - $40 coupon - 500 qpoints - 32 qcoins - free delivery coupon)
mosmos
