Xiaomi Redmi Note 2
clay9477
This is the whole purpose of encryption and security. Ie no one can read. If data is important. You should have backup somewhere else.
Yep. Problem is Xiaomi is not expecting users to hold super impt info in the sd card or to even use the phone as corporate phone[got blackberry]. They just targeting mainstream users, hide unglam(wink wink) photos or videos or basic documents only. Different market i guess but if enough support, the devs will consider to allocate resources to setup encryption for sd card.
eedwinn
Bought the phone for work use and realise it's not compatible with my work's E-mail...
Looking to let it go at $209 which I've bought from Xiaomi SG website, only set it up and used for a few days. Even the layer on plastic on the screen is still intact.
PM me if interested! :D
RaptureM3
how is it not compatible with work's e-mail? care to explain further? as far as i know all androids' backend is the same regardless of MIUI, touchwiz, etc.
eedwinn
Something to do with the encryption... My work e-mail requires some encryption set-up and downloading of the in-house apps in order to work, which apparently can't be done on Xiaomi phones...
cscs3
Problem is not only once they say about Their phone not able to install application on SD is due to security reason!
cscs3
Yes, some company require smart device to have some kind of program like Mass360 (may be I missed the application name) before you can use the device for business purpose.
Daffy7
my new phone from SG xiaomi keeps encounter this error msg...
anyone encountered the same error?
skrw105
i have the same error message, but the phone continues to function normally.
dont remember seeing this error during the few hours after unboxed.
think after flashing to global beta rom and transfered everthing from redmi 2e, this appears quite frequently.
edit:
thanks for the solution.
the play services version remains 8301 after re-update.
and dont forget to re-activate the Android Device Manager.
ArcticCheetah
Some sec com policy requires encrypted phone but XiaoMi no such function, I would encourage you to complain to XiaoMi Loudly if you want it fixed
imp0ssibled
Do you guys find that the ram usage for this phone is high? I seem to have 1gb of free ram left even after rebooting.
imp0ssibled
Quite common for Miui. But 2G should be more then enough for day to day.
Ya but I had the redmi note 4g before this, and it had 1.3 to 1.4g of free ram after rebooting. But then that was on miui 6, and this note 2 is on miui 7. Maybe the difference in ram usage is cos of the miui 7?
spidey19
Sometimes use cleaner to clear all recent apps still only left 600mb ram, den have to reboot to get 1gb ram. Dunno issit android or MIUI problem
Daffy7
My battery draining like mad as compared to xiaomi redmi note 1.. Anyone experiencing this?
imp0ssibled
Ya same here, after clearing recent apps, only 600mb or so ram left too.
Also the batt life goes down faster than my redmi note 4g too.
Daffy7
xiaomi website don't have stable 7.0.11 rom. may I know where you got it from?
