Ya this phone eat alot of battery, now using 7.0.11 global rom slightly better battery life.
xiaomi website don't have stable 7.0.11 rom. may I know where you got it from?
Isnt 7 considered miui6 right? Why still using miui6?
My battery draining like mad as compared to xiaomi redmi note 1.. Anyone experiencing this?
funny. i didnt experience battery draining issue. i start my day with a full charge at 7am and last till all the way till 10pm with 40% left. I surf lots of nets, facebook and occasional video on youtube.
mousepad_88, are u on 7.0.11.0?
how to turn on the battery saving?By default, the battery saving is not turned on.
Could it also be due to difference between Wifi (n or ac) and 3G/4G, screen brightness ?
Where did you get that version? It's not on their site. The battery drain is affecting me too.mousepad_88, are u on 7.0.11.0?
Sent from Xiaomi REDMI NOTE 2 using GAGT
I found it on lowyat forum, not sure appropriate post here or not.
So far I use a few days quite stable, no overheating or wifi prob. Overnight with wifi on only eat ard 5% battery, consider quite gd for me
should be appropriate? can share the steps?
thanks..does this stable ROM has Google play store?http://bigota.d.miui.com/V7.0.11.0.LHMMICI/miui_HMNote2Global_V7.0.11.0.LHMMICI_2cf833e246_5.0.zip
Just follow the flashing guide on MIUI website lor, juz make sure to backup ur stuff
. Still using 7.0.8.0.Other than the Google Play services bug which is solved easily, I'm extremely happy with this phone.
This version is non-wipe right? I didn't see it appearing on the updater app. Still using 7.0.8.0.
Yes...
Not sure what u meant by non wipe.
I think Xiaomi has taken down from the updater server. Sat got 7.0.12 update also got taken down after awhile.
So far I use 7.0.11 global is no prob, but update at ur own risk bah since nt avail at official server.
Non-Wipe means flash liao the data/apps still there.![]()
