Xiaomi Redmi Note 2
imp0ssibled
Would you all buy a screen protector that has no cut-out for the front facing camera, but it's covered instead?
csc12345678
Hi ! I wonder if it's possible to switch on the phone using the volume (both up and down) buttons instead of the power button ?
undead102
Can. Settings can change. I wonder if can wake up the phone without pressing the physical button.
BTW I love this phone. Been a Samsung user for a very long time. Very impress with xiaomi and miui. The Interface and ui very clean and sleek like ios.
Anyone knows how to solve the status bar keep showing when watching video in full screen mode with the miui video player?
Shutterx
This one you showed, has a cut-out hole in front for the front facing camera.
But I bought a tempered glass sp from qoo10 and it didn't have a cut-out hole in front for the front camera, and I felt that it was quite strange.
if front camera has scr protector covering it, ur photos will appear in lousier quality.
install bsplayer or mx player
Anyone using File Manager on this device ? Do you have both sdcard0 and sdcard1 ?
can see 'phone storage' or 'SD card'.
for me, 'ES file manager' is better to use.
Shutterx
Isn't this available model Note 2, why they claimed as Note 3?
'Latest XIAOMI REDMI NOTE 3 5.5inch Full HD Display / Octa Core 64 bits / Smart Mobile Phone / 2GB RAM / 16GB ROM / Export Set with 6 months Warranty' SLS Shop
http://list.qoo10.sg/item/XIAOMI-MO...DMI-NOTE-3-5-5INCH/440050896?selectedOptions=
its the lower specs Note 3, then with the fingerprint sensor behind and non-removable battery
Devilsire
inferior tempered glass =:p qoo10 mostly are those taobao's mass import of cheap qualities (eg. 5-7H advertised as 9H )
front cam might blur abit. just make sure there's cuthole for the proximity & light sensor
csc12345678
I find that the I can always switch on using power and volume up button. However, the volume down button does not work all the time. Anyone notice this ? Software/hardware problem ? Thanks.
spidey19
I got this prob on 7.0.7 global rom, update to 7.0.11 den can work liao :s12:
imp0ssibled
Ya same problem, only up button can wake the lock screen
imp0ssibled
Ya the front camera now not as sharp as without the sp covering it.
clay9477
Tap to wake gesture has already been highlighted to MIUI dev. They are currently working on it but no timeline for Redmi Note 2.:s13:
