Xiaomi Redmi Note 3
kelvinti
I saw a lot of user here using ipaky case. Will it make the phone very thick and bulky? I admit it looks nice.
Currently, i'm just using it with transparant tpu case.
Keep the transparent TPU case to keep the good look and color of the phone. Don't cover the beauty! It is a waste! .... :)
Kitaro9202
Heavy gaming on hp
Sent from Xiaomi REDMI NOTE 3 using GAGT
asdyui31
Anyone know how to make the notification light work on whatsapp? Just bought this phone ytd..
ZhuTou!
Ur setting is white light?
My light works ah but i noticed white light less obvious so maybe u didnt see the light
kelvinti
MIUI can show WhatsApp notification light wah... Nothing need to be set besides color.
lingua101
I just got my Redmi note 3 shipment today. I am rather disappointed on 2 things
- the dual SIM card does not support let on both SIM card like Redmi 2 and use micro and nano
- the SIM card design is like iphone, you have to use pin to open, very annoying as I change SIM card very frequent especially for reason 1, which I have to keep changing SIM card when I travel, as only SIM card 1 support lte
ZhuTou!
U dun research before u buy things?
amazingone
Impulse buy is it:)s11:), I always thought people would at least google enough for infos before settling down on a phone, especially that you have an 2007 hwz account..
Sent from my Rice phone using GAGT
amazingone
Well I did, but did not really notice about the hybride SIM card le. I assume if Redmi 2 support both lte, then higher version cannot be worse off right.
Does note 2 also the same?
Redmi 2/3 and Redmi Note 2/3 are advertised as 'Dual 4G Dual SIM', but when there's two SIMs, it's on a 4G+2G dual SIM network combination.
Only Xiaomi devices such as Mi 5 and Mi Max support 4G+3G dual SIM network combination.
lingua101
Actually some review mentioned it it support lte on both Sim
Should your network be supported, however, the Note 3 offers 4G connectivity on both of its dual-SIM slots (this is a dual-standby phone that accepts two Micro-SIM cards).
lingua101
Confuse. What you mean?
So if I choose Sim 2 for Internet it can run at lte also? But Sim 1 become 2g?
amazingone
Indeed, both slots support 4G networks but the technical thing is that when there's two SIMs in the phone, it's on a 4G+2G dual SIM network combination.
And also, the source that you quoted me is the MTK RMN3 variant, which isn't the one that's retailing by Xiaomi Singapore.
The MTK RMN3 supports dual micro SIM but no SD card support, while the SD650 RMN3 supports micro SIM and nano SIM or micro SIM and micro SD.
