Xiaomi Redmi Note 3
Oinkize
Yes phone only
I'm posting from the phone now. I not sure if I got scammed though. But seems legit.
Sent from Xiaomi REDMI NOTE 3 using GAGT
Novel is singtel auth dealer. Dun worry.
ahber79
Checked out Plaza Singapura. Starhub only sell with contract now. M1 authorised dealer got no stock. Singtel authorised dealer selling at $368. Price increased from $299.
Thoreldan
Got one set at t3 m1shop for wife.
Gold, $310 bundled with prepaid card (think is $15 value)
PC-User
This thread has temporarily taken a step back - from technical discussion about the phone itself to, where to get the damn phone! :D
kelvinti
Anyone who wants a piece of mind. Just give a call to Xiaomi hotline to check your phone IMEI.
They are able to tell you if the phone you bought is indeed covered under Singapore local warranty or not. Simple. :)
wsoybean
Yesterday went to far east and bought redmi note3 from mobile square , so far so good...happy with performance :D
32gb gold at $298 cash.
+$10 for tempered glass
+$10 for back cover
amazingone
Paiseh I noob arh.. But is the anti blue light tempered glass the best?
And what's the difference between air cushioned case and transparent case? Which one Better arh?
Sent from Ilovennp using GAGT
Anti-bluelight is a recent new model of tempered glass, helps blocks off harmful blue lights from the display.
Air cushioned case will better protect your phone when you dropped it, but I didn't tried it before, just taking it from their description.
However, the back design got this Hansaplast dots design, something like Galaxy S5's back cover design. If you don't like it then get the normal one will do.
Sent from my Rice phone using GAGT
kelvinti
I had gone to taste taste a bit of MIUI8 China Developer ROM 6.6.23 for 20 hours. :)
I would say it was a delicious MIUI8 experience compared to MIUI7. :s22:
In MIUI8, you are given more controls and more choices on how you wanna use your phone and the updated MIUI8 animations/effects are refreshing too!. :)
I can't wait for the MIUI8 Global ROM to be released for our awesome RN3.
I'm now back to MIUI7. :)
