Xiaomi Redmi Note 3
JivBunny
Ask your telco "What if I lost my phone? How much does it cost to replace SIM card for that?"
I cut from normal SIM to microSIM twice and both card are ok. Tips to take note is cut slightly bigger then file it to the right size. It'll also help if you can cut with a wire cutter instead of a normal scissors.
If you lose your phone and provide a police report, they will replace a SIM card for you (based on the size they issued to you originally for free)
Tried and tested. Unless you recon or buy a phone that runs on nano. Or pay to change the size.
So for those people out there, when you get a new phone, choose the nano sim and get yourself an adapter
kelvinti
went bugis one, no stock. they told me they don't sell without contract. any guys have simliar experience
They used to sell without contract back in May.
I bought it from them at $299 nett in early May over the counter in less than 5 minutes bah!
I guess that StarHub has started to control the stock to reserve for contract buyers due to high demand and limited stock at this moment. :(
So, Ladytoto90. Aren't you offer any here again? I dare you lol..
i1magic
Those who wants a SIM cutter.
Item : 2 in 1 Double SIM card cutter micro & nano cutting
Price : About SGD$4.80
Source :
http://www.ebay.com.sg/itm/2-in-1-D...973016?hash=item41a3dbeb18:g:z8QAAOSwFMZWqyeN
TitanSmall
there's one hp accessory shop at far east basement.. sells v cheap cases.. if u buy something there..he will cut ur sim card for u free...
Kitaro9202
RN3 no NFC right?
Normally this shouldn't happen. You have lots of conductive stuff in your pocket? Or try to use a thicker case.
My pocket put hp nia if the fingerprint sensor facing my leg there it keep vibrating
PC-User
Normally we keep with screen facing in lah. Like that when you knock on something the screen won't crack plus take out to use also more convenient.
Even if you put with finger print scanner facing in also, I can't understand why it can be activated so easily because it's recess inwards not protruding out. Try to control your force and see...
