Xiaomi Redmi Note 3
Nakedtoes
7.3.7.0 have fingerprint unlock issues.. I kana twice.. It happen when whatsapp come in. Need unlock manually.. Then I re register my fingerprint ok liaoz.. See how.
kelvinti
Try to recall if the front sensor on the top part of the panel was somehow covered or blocked by your hand or fingers or anything when it happened.....?
kelvinti
I noticed that Google and Android services drained my battery literally from 96% to 3% over 15hrs (left the phone at home)
What could possibly be running by them?
Screen is not awake most of the time
Sent from Xiaomi MI NOTE LTE using GAGT
:eek: That's strange!
My RN3 has been normal. Nothing has been draining my battery since day one.
For example:
Over the course of 3 hrs 38 mins.
Android System took up just a mere 8m and 32s of CPU Total only.
Google Play Services took up just an unnoticeable 1m 30s CPU Total only.
kelvinti
Side track a bit...Chinese music folks,
What App is the best for detecting Chinese song with information and name of the songs in Chinese? :s8:
My Shazam App is bad in giving me the detected songs in English only as in pinyin, and I'm blur about pinyin. :o
treeskull
kelvinti
I just kenna several times.... Now totally unusable... It's like upgrading firmware... Can't even use the phone... =(
Sent from 화장실 using GAGT
I do encounter it too in few occasions but not frequent under normal usage.
Just need to use the power button and then PIN code to unlock the screen once and the fingerprint unlock works again.
It is indeed a bug that has been present since day one.
garychengjw
PC-User
Wow that's too much. My RN3 consumes 3% battery for 10hrs standby (no Facebook & Messenger installed)
How long have you not reboot/clear RAM your phone?
walkofwinners
Not sure about that with unlocked bootloader.
However, I'm super sure and have been doing that with a locked bootloader. I can miflash freely MIUI official rom be it Stable, Beta or developer rom on both the global and China version.
Technically, it should be able too with unlocked bootloader.
gamxia, let me try tonight and see if my phone survives :s13:
burger
it started in the morning with loss of 3/4G, as off and on back data did not work, i rebooted.
everything fine till whatsapp msg came in and the phone froze...in the end, not sure what happened, the phone rebooted and i got the screen similar to a firmware upgrade....
after that so far so good, lucky nvr lost any data on the phone and the fingerprints were still there....
:s22::s22:
Nakedtoes
Nothing lar.. Cause after unlock manually I lock then can use fingerprint. But if what's app come in cannot. Now after re-register fingerprints no more occurrence
Nakedtoes
if i'm not wrong for whatsapp if you enable the "pop up when screen off" and when the screen goes back off, the fingerprint to wake doesn't seem to work.
Mine disable pop up but top screen will show if whatsapp come in
kelvinti
:s22::s22:
Strange event indeed!:s11:
Wah! Lucky you! :s13:
