Xiaomi Redmi Note 3
kelvinti
my note hanged again this am when i was unlocking it and a whatsapp msg came in :(:(:(
Hmmm... Due to WhatsApp pop up?
Actually, do you really need the pop up?
I always disabled the pop up since day one as the 3 type of notifications from the status bar, Notifications list and floating notification are good enough for alerting me and it takes just extra 1 to 1.5 seconds to tap and reply. :)
More privacy and safer too without the incoming pop up especially so when you are gossiping... Kekeke. :)
burger
under whatsapp settings, popup notification is set to "no popup" leh
bbcccc
that's wat happened to my dotter's rmn3 too
hanged after watsapp pops up n hv to forced shutdwn
after that, fingerprint scanner stopped wrking...
burger
heng,for me the fingerprint sensor still working after the force reboot :eek:
did u try to update the rom again, like what kelvinti mentioned?
eviler
Actually, I am hoping for Android 6.0.1 to be available for Redmi Note 3 soon. Mi Max is already on Android 6.0.1 liao.
With Android 6.0.1, battery life should be even better.
I think should wait long long. Xiaomi never had a history of updating Android versions. Instead, they make a big fuss of their UI and try to blind users into thinking it is better than a whole OS upgrade. :s13::s13:
bbcccc
can't
tried le...
wait for new update ba...
walkofwinners
Phone bricked Liao :(
it can be salvaged if you can get into fastboot mode.
force boot it into edl mode via fastboot and use miflash to flash a fastboot rom and you are good to go.
on a side note, i'm on mokee cm 0629 now. battery life is insane, got 6 hours screen time with 37% left.
