Xiaomi Redmi Note 3
lonestar86
i'm shocked to notice that the quality of the photo taken using redmi note 3 is not as good as my good old redmi 2:o
treeskull
Guys anyone with the same problem as me? The mobile network system turned red?
On 6.7.29
Sent from 你是我的小啊小苹果儿怎么爱你都不嫌多红红的小脸儿温暖我的心窝点亮我身命的火火火火火火 using GAGT
Just Me
treeskull
i1magic
Ok. I wanted to do a reset on my RMN3 since there seems to be a battery drain problem.
So I tried to copy some folders (400+MB) from phone's internal memory to my microSD card. But don't know why, the copying takes like forever.
Can somebody try and see whether does any of you has that problem also?
Thanks.
Seehuatsee
Thanks.
Kelvinti got same problem as you
lewissac
Is there any reputable phone repair store than can fix export phone?
Last week was at Xiaomi's Service Centre to replace my mi4i battery (it was very quick and instant, not to mentioned pretty affordable with 6 mth warranty).
When asked about my RMN3 export phone, they say they can't fix it for me as it is not a local set. Hence. I wonder if there is any store that can fix export Xiaomi phone?
xiaoyuer89
My phone was fully charged and I use about 23m SOT before I slept. When I woke up, battery show balance 81%. *fainted*
Don't know what is draining, so I resetted my phone. Hopefully it'll get better.
Same here.. Will be following. Hope someone have the answer to this... Just one month of usage on this phone..
Just Me
Thanks.
Check your android usage and battery temp. If both are normal then try a factory reset.
I tested using filezilla ftp client with the default file explorer ftp server copying a miui 8 firmware file over 1gb while I was on miui 7. Speed was normal using wireless transfer at 14-16Mbps. Didn't try using cable yet
Sent from Jiak Liow Bi phone using GAGT
i1magic
What I mean is copy a folder from the phone's internal storage to external microSD card.
