Xiaomi Redmi Note 3
i1magic
What I mean is copy a folder from the phone's internal storage to external microSD card.
Oops ok I just tested it is indeed very slow as I tried with a 5mb file and it took more than 30 secs.
Sent from Jiak Liow Bi phone using GAGT
Yah lor, the transfer is very very slow and it is not about the speed of the microSD card because even with the slowest Class 2, it wouldn't be so slow.
I remember that on MIUI 7, I could still copy without any problem.
Tech n Travel
could it be the transfer cable?
but then again.. weird.. then u try copying the files into a SD card take out and copy it out to your computer..
reset factory and try again.. see if still have the same problem.. if yes then report bug ba :)
i1magic
From phone's internal storage to microSD card in microSD card slot, got what cable?
DigDub
Ya. Considering going back to 7.3.6.0.
How to flash back to MIUI 7? Can I just use the Updater again?
have to use the .tgz and miflash method to go back. that's what I did for going back to 7.3.6.0. 7.3.6.0 still the best so far.
