Xiaomi Redmi Note 3
fitzz82
Thanks to Kelvinti bro's help, I managed to flash the MIUI 8 Global Beta 6.9.9 ROM this morning.
It was a tedious process I must say.
Few things to note :
1. When you install MiFlash, install it in the default folder (I act smart and change it)
2. Whichever folder name or file name you used, CANNOT have any space
Once again .... BIG BIG
GAM XIA to Kelvinti bro!!
did u lose all yr config and data info? or u sync yr data out 1st?
im tinking of doing it too.
Hyperephania
Bought the phone, probably coming in a few days. Just want to check with you guys here.
1. Are there any guides on how to "change" the ROM?
2. Which ROM is the stable ones or the ones you guys are using now?
3. Where do you guys buy your accessories for the phone? e.g. screen protector, casing etc
Thanks in advance!
treeskull
Thanks in advance!
1. http://en.miui.com/a-232.html
2. I'm using the global beta rom currently on 6.9.9
3. U can check qoo10 or go pasar malam those phone shops ask
Sent from 你是我的小啊小苹果儿怎么爱你都不嫌多红红的小脸儿温暖我的心窝点亮我身命的火火火火火火 using GAGT
niwde1980
hi all sorry to OT.. I currently using Note 3 Pro which is really a good phone.. but I feel the camera quality not good enough.. is there any higher end xiaomi phone can consider ?
sorry again to OT this thread...
i1magic
The phone is fresh out of the box, so nothing in it, so I don't know. Must wait for Kelvinti to answer.
i1magic
Thanks in advance!
I bought most of my phone accessories on eBay / Aliexpress.
i1magic
Don't bother liao. Just improve on your skills. Play around more with the phone's camera and find the best way to take nice pictures.
Problem solved. LOL!
Oinkize
Wa. So simple! 'Does the visa uncle dance.'
skrw105
just realised that my phone is on 4g / 3g connection.
skrw105
should be aft. updating to 6.9.9 global beta.
that could be why my battery life is not as good in the past few days.
