i1magic
- Dec 11, 2002
Can I confirm that the 13hrs+ SOT, bulk of it you are watching video? If yes, was it via YouTube streaming?
YouTube stream around 1.5hr+..Wah! Even more power. Which firmware are you on? How many hours it last after unplugged?
Wah lau, wanted to buy this casing which I paid about $1.40 previously. Now price almost doubled!!
Item : Clear thinskin shock defender TPU silicone case
Price : About SGD$2.70
Source :
http://www.ebay.com.sg/itm/Clear-Th...hash=item4649feb41a:m:mki6C3L4y3vXx9iSNdSekSg
the latest miui 8 batt life is good![]()
Anyone got idea why using latest stable miui 8 rom and Instagram still lags after loading a lot of pictures in explore tab?
I got serious battery drain issue, from 85% to 57% overnight. I had switched off sync and GPS, and had turned on airplane mode. Any idea what's the cause?
Same. Having drain with Android, Android system. Maybe 5-10% overnight. Restarted with no avail. Only luckily battery is large.
Standard OTA updated to MIUI 8 Global stable. Hoping future updates plug the leak.
Thanks to Kelvinti bro's help, I managed to flash the MIUI 8 Global Beta 6.9.9 ROM this morning.
It was a tedious process I must say.
Few things to note :
1. When you install MiFlash, install it in the default folder (I act smart and change it)
2. Whichever folder name or file name you used, CANNOT have any space
Once again .... BIG BIG
GAM XIA to Kelvinti bro!!
