amazingone
- Jan 14, 2015
If your mom's usage not so heavy, 2GB RAM is enough~Wah lau... So big diff sia...If is 3GB ram I will definitely mtl!
Sent from Sumire using GAGT
If I get the 2GB/16GB version, can I flash to global ROM using the ROM files on the Xiaomi website? The Xiaomi website has no distinction between 3GB/32GB and 2GB/16GB (unlike the Xiaomi Max which differentiates between the different capacities)![]()
Go for Note 4. Already MM. Note 4 nicer. MTK chip isn't that bad. Performance comparable to SD.It should not be an issue. I got the export set of 2GB/16GB and flashed to latest official ROM. Now waiting for marshmellow version to be released.
What's working :
Boots
RIL (Calls, SMS, Data)
Fingerprint (FPC1020 only)
Wi-Fi
Bluetooth
Camera
Camcorder
Video Playback
Audio
Sensors
Flash
LED
GPS
What's not working :
Camcorder can be a bit buggy at times.
Instructions :
Download the latest build and GApps
Reboot to recovery
Flash the latest build and GApps
Reboot
Downloads :
Build: https://www.androidfilehost.com/?w=files&flid=110842 (Mandatory: Flash the updated firmware first)
Google Apps: http://opengapps.org/
Credits :
@banmeifyouwant: For his kernel patches
@luca020400: "Me: HAALP!" He answered me
CyanogenMod Team
Xiaomi: For providing the Kernel Source Code
XDAevDB Information
CyanogenMod 14 for kenzo, ROM for the Xiaomi Redmi Note 3
Contributors
TheStrix
Source Code: https://github.com/CyanogenMod
ROM OS Version: 7.x Nougat
ROM Kernel: Linux 3.10.x
Version Information
Status: Beta
guys just checking can the 2nd sim slots support 3G? so that when using dual sim at least another slots still can use...since ida decided to cut off 2g for good in next year T-T
Anyone has any good clock widget to recommend?
How to get the default 1 to show time on your home screen? Not talking about the notification bar 1 but I want a bigger 1 on my home screen similar to lock screenUse the default one. Though not significant, using others will cause batt drain.
Both slots support up to 4G. But only 1 slot can be used for data at any one point of time.
confirmed working on xiaomi developer rom. flashed to qualcomm AOSP MM yesterday and also 4G+3G. Prefer this to Miui...
I use DIGI clock widget. Don't see difference in battery consumption probably because the battery life is too good to be affected by a little widget.Anyone has any good clock widget to recommend?
Go to widget and choose the one that's 4x2. Something like that.How to get the default 1 to show time on your home screen? Not talking about the notification bar 1 but I want a bigger 1 on my home screen similar to lock screen
Sent from Xiaomi REDMI NOTE 3 using GAGT
Yes can. Mi max have different firmware due to the different CPU inside (650 and 652).If I get the 2GB/16GB version, can I flash to global ROM using the ROM files on the Xiaomi website? The Xiaomi website has no distinction between 3GB/32GB and 2GB/16GB (unlike the Xiaomi Max which differentiates between the different capacities)![]()
