Xiaomi Redmi Note 5
hyper_megaman
At the moment yes, but I suspect upcoming Mi Max 3 will have this "feature" too. Seemed like it's a Oreo feature so may be will affected those device running Oreo.
https://www.xda-developers.com/android-oreo-rollback-protection/
does this affect china rom?
i just sent my china set for RMA. expecting to get it back in about 2 weeks' time and to get the shop to help flash to global at the same time.
wah hope i'm not stuck to my china rom!
kuma-mon
Oh man, the anti rollback is gonna be a big issue. I read reports there is no way to install fastboot roms, even EDL mode will fail after u update it. How to install custom rom like that.
ZrE0_Cha0s
most likely they want use to keep using MIUI or maybe they just want to follow apple?
ngbc
It only happens once u update to miui 10 8.7.5?? If using miui 10 beta previous version still okay??
Posted from PCWX using ONEPLUS A6003
is there any way to flash to global rom in this case?
My understanding is :
The last builds without anti roll-back are:
Global Stable (Miui 9) 9.5.17.0
Global Beta (Miui 10) 8.7.5
China ROM (Miui 9) 9.5.21.0
China Developer (Miui 10) 8.7.5
If you're on the above rom, you can downgrade and cross-flash (china to global & vice-versa) to lower version.
If you're on say China ROM 9.5.22.0 you can cross-flash & upgrade to higher version but cannot downgrade to 9.5.21.0 and below...and apparently cannot flash custom rom ... :(
ngbc
Yes, affect China rom too :
http://www.miui.com/thread-16409635-1-1.html
But you can still flash to global rom, just that if the China ROM is 9.5.22.0 or above, you can only flash to Global Stable 9.5.19.0 and above...
hyper_megaman
so is there any issue with cross flashing on the latest china rom?
there was an older version of the china rom that required u to flash to a lower version before u could cross to global right?
hyper_megaman
Haizzz, this move will affect xiaomi greatly. What is the purpose of having project treble then. What if we flash custom rom that has latest version of android, does it still work?
it's an inherent android function i read, not much to do with xiaomi
ngbc
On the custom rom part, still not too sure...
Anyway, there is an Unofficial FAQ on Anti-Rollback that said can flash custom rom... so just wait for further development :
http://en.miui.com/thread-3214779-1-1.html
ngbc
May be just stay on existing China rom first (and install the Google Play) while waiting other to test out ... since yours is export set, cannot send to Mi Service Centre if anything go wrong!
hyper_megaman
aiya mafan.
i don't want to go back to simlim once more just to flash global. i'd rather do it all one shot.
also jialat now that the rom auto updates OTA. even if u don't press it, it will update anyway.
where should I go for discussions on people who cross flash different region roms? can keep an eye out
Hotsnow
aiya mafan.
If accidentally pressed update, can go downloaded rom folder to remove the new rom file.
android17
Anyone knows where got good price for note 5?
Searched lazada, only see $249 for 32gb, with local warranty. This isn't a good price right?
kuma-mon
Lol, i receive my redmi note 5 today in the mail, everything sealed in plastic all..but when i boot it up for the first time, strangely it doesnt ask me to set up straight away boot to home screen. Then i go to settings, check the bootloader is already unlocked lol
Means my device is used and not mint condition. But im also happy coz i can straight away flash custom roms lol
Just Me
From JTBC? What's the default firmware which came with it?
ngbc
aiya mafan.
Dun see any thread on that, only those that hard-brick rn5 after downgrade from Miui 10 Beta rom...
Since yours RMA case and the shop doing the flashing, why worry? The shop should be very good in this....
kuma-mon
Not jtbc, some random mobile shop name at lazada. But im alright with it though. Default come with miui 9.5 global rom but its unlocked. Luckily not the latest version
Posted from PCWX using Redmi Note 5 Pro
