Xiaomi redmi note
lazy999
anyone facing brower load very slow or dont even load at all? I tried using the default and google chrome browser also facing the same problem.
One more qn, whatsapp cannot download from google play. its just shown downloading. After a long wait, still downloading. Anyone can advise?
hyper_megaman
did u enable limiting downloads to only when connected to wifi?
disable that in google play settings to dl on your mobile network
imp0ssibled
Hi, is the redmi data graph suppose to be showing in 2 hour blocks? Because mine is showing in 2 hour blocks.
animeonegai
I got the note. It is at least 2 times longer battery than S3 and charge noticeably faster.
The other thing to note is the audio quality is worst than S3 and not as loud as it is in terms of headset volume. Not a good thing.
Last thing, I had to get it root straight after update. Spent 2.5 hours just to get the basic things right back to my previous phone status. USB Driver took 1.5 hours or more just to get things working. Aka no proper guide on this...
Overall I'm still testing it out. But the fact the battery life is longer than S3 already wins 2 points.
hyper_megaman
agree
in any case, my major beef would be with miui. don't really like its simplified interface; i prefer stock android (or something close)
still, i guess that's a horizontal shift
ohj81
Anyone using Bluetooh headphone with Note? The forward / reverse track buttons only adjust the volume and not skip tracks, any workaround anyone?
hyper_megaman
Thanks.. Managed to upgrade to v30.. Think I must have accidentally d/l the China room update by mistake.
no la it's just a corrupt download
i got one that was corrupt too, it seems to be something to do with this server
Johnteoh
Go to Setting>Headphones. Change to control music playback.
kenapa siol
Upgraded from v23 to v30 yesterday using the wcdma zip file. Interface seems cleaner and better. Thou chrome had issue launching, but re-install it then problem solve.
Unable to access play store for around 30mins. Everything went back to normal liao. Rooted the note but un-sure what can i do with it since i've been a iOS user. Any advice?
hyper_megaman
rooting? not much unless you're looking to run game hacking apps. there's less point in rooting to change the interface since miui is quite customisable (themes, etc)
i keep my root disabled most of the time, in case i accidentally allow stray programs to use root functions
laironpark
Seems like note fever has subsided. 2pm still have stock available. Only the powerbanks are flying off the shelves in seconds.
Just Me
Having ready stock is always good news for end users and bad news for flippers :D
geckoSG
I'm not surprised that there is still stock... Its over-rated hype in the first place...
