mingfreakrsx
- Dec 6, 2013
fresh player upgrade required?I cant play Facebook video, when click on video, message "fresh player upgrade required" will appeal. Any ideal how tonsolve it. Both Google chrome n default xiaomi browser give same issues.
Is flash player upgrade requiredfresh player upgrade required?
or flash player update required?
Thanks, but after instal it work on default one but not Google chromed. But cant play facebook video again today.
Check link a few posts above. Step-by-step process to install adobe flash
Hi
Any help would be appeciated
Can Only save to Internal memory
Downloaded to latest 37
Is my Note faulty ?
Settings → Storage (scroll to bottom) → storage setting
I got this USB cable. I charge my Note 3 with the stock charger and I managed to get 1.82A max.
Item : Visible LED Light USB Data Sync Charger Charging cable cord for Smartphone
Price : About SGD$2.20
Source :
Visible LED Light USB Data Sync Charger Charging Cable Cord FOR Smartphone CM | eBay
1.82 is good or bad?
are you maintaining the chart with measurement of all the diff cable?![]()
