Pre paid card for use in redmi note should using sim1 or sim2? if don need data or dont wan to accidentally use data,which 1 should i use?any different in voice call between sim1 n sim2?
Use any slot also can.
Under Settings > Wireless & Networks > Mobile Networks > Data Connection > Enable (Switch to Off)
Under Data Roaming > Data Roaming > Switch to Off
Shouldn't have any difference in voice quality in either slot but since you only have one SIM card, just slot in the 1st slot so you get both 3G and 2G network coverage.
Thks for the replyremoving it will remove the google search function.
for existing S4 user, Mi Note / Zenphone 6 is considered as down or upgrade?
I find the 3g speed slow on my Xiaomi note. Can anyone post the speedtest result you guys are getting on 3g?
The case I bought on eBay is here. This is not original Xiaomi case, since they don't make it in this colour from what I can see on their China site. About S$8.
It feels pretty cheap. The red paint job isn't completely even, there are a few raised spot from imperfect paint job. The button feels pretty cheap too. Since I don't have a Redmi Note anymore, can't be sure how it fits though.
