Xperia Arco S
pker88
one thing I find the acro s
fm tuner appls
don't let use use a widget to quick access as it don't have a fm tuner widget as compare to s3
and when. use the fm tuner on Arco s it on the notication ya ok but it seem don't let u one click to access it fm preset it will only scan scan
which is not as friendly
as s3 xsn do this on noficstion plus it got it own fm tuner widget too
wonder is there any appls on Google play for the phone fm tuner or not since mp3 got it own 3rd party appls such is enhance it
pker88
one more thing is example on s3 u hold home buttons u can access to all the appl currently running and. got 2 button below
clear ram and clear all appls
on top of swipe left to kill appls
which is quite friendly
but on Arco s no button only swipe left to kill
so how can we clear ram and kill all appls in one go
use a 3rd party appl?
so this little thing its quite useful as s3 incorporated it in its ics
I'm still hope sony adds more user friendly features too
hahaha u all may say I'm now a sammyfan hahaha
but all this little things makes the user experience more nicer too
carlover76
fm tuner appls
Whether it comes as stock application or feature, it is just a bonus but not necessary as Android market or other markets allow you to find many free applications or widgets.
Those who require the FM Radio widget, you can install the TuneIn application which I preferred this app using internet streaming versus the FM reception.
pker88
ya what u suggest is good but steaming is not so good now days as data cap is lower and drain battery even more so good old sch FM tuner is still the most efficient way
anyway our mobile internet sucks too
hush66
Review from Digital Life:
Two days ago, I nearly emptied a glass of water over a review unit. I was quick enough to save the phone from a watery death. But if the phone had been the Sony Xperia Acro S, there would have been no need to rescue it.
Not because it is not worth saving but because it is engineered to survive being splashed or even dunked. Briefly, at least.
Sony says the Acro S should be okay if it has water poured on it from a height of 3m for up to three minutes.
It can even be submerged in 1m of still tap water for about 30 minutes.
This Android smartphone is sealed tightly to protect its various connection ports.
Its protective plastic covers are not hard to peel off but they are hardly aesthetically appealing. They also get in the way when I plug in the earphones or micro USB cable.
Physical buttons are planted on the right of the phone. The power button is both small and stiff. The same can be said for the volume and shutter buttons.
Weighing 147g and measuring 11.9mm thick, the Acro S is definitely a space hogger in my pockets. But it does feel solid in my hands. However, the combination of a thick, smooth and curvy body means a slippery grip.
Three touch-sensitive buttons – back, home and menu – are clearly marked and located just below the 4.3-inch screen. The buttons are not as responsive as I had hoped.
The Acro S runs on Google Android 4.0. There are hints of the Ice Cream Sandwich interface but mostly buried under Sony’s heavily customised user interface. For example, the music and video player are split into Walkman and Films apps, instead of a single Gallery app.
I noticed an improvement in the images taken by the 12.1-megapixel camera and the autofocus is fast. But noise artefacts do appear when lighting is not favourable.
With the Mobile Bravia display enhancement, videos are rich in colour and details are sharp on the display with a screen resolution of 720 x 1,280 pixels. Audio performance is average at best but you get various equaliser settings, such as bass boost, to work with.
Power consumption is relatively high, judging from how it went flat after I had used it for about 11 hours for WhatsApp, Twitter, calls and Web browsing. Looping a video, with the phone’s brightness and volume set to the maximum level, killed the battery in slightly less than four hours.
Besides the large screen with a high resolution, the Qualcomm dual-core 1.5GHz processor may also have taken its toll on the battery. On the bright side, the processor rendered webpages quickly and video playback was smooth.
Get the Xperia Acro S only if you spend a great deal of time outdoors exposed to the elements so the protective features will make a difference.
TECH SPECS
Price: $698
Operating System: Google Android 4.0
Processor: Dual-core 1.5GHz
Display: 4.3-inch LCD/720 x 1,280 pixels
Camera: 12.1 megapixels
Battery: 1,910mAh
RATING
Features: 3
Design: 2
Performance: 3
Value for money: 3
Battery: 2
Overall: 3
Recommended retail price is $698.
blackslayer
those who tried the phone.
is the phone very thick ? worry that once + case become super thick :s13:
considering between this or the god knows when mint
roughly the same thickness with xperia s. the wet tracking screen is good. anw album has been improved unlike the old gingerbread gallery. there is finally oen dedicated video player on board. one good thing about this video player is that it does shows u the synopsis of the movies u have inside. if it is those movies downloaded from pps or pptv. the video will allow u to edit the name and uses gracenote to search for media information.:D
Oinkize
Dun care about their ratings lah. as long as you like it then you buy it. as simple as that...
ashethen
Acro S unboxing
looks like the dock is standard. can charge without opening the flaps
Spock
Sony Mobile SG has just officially launched these 3 models :
Xperia™ acro S, Xperia™ go and gorgeously HD Xperia™ ion:s12:
Facebook link
Spock
Rock Quicksand cases for Xperia Acro :D
hush66
Telco when start selling?? Today? Anyone know the price?
Should be on sale from tomorrow onwards.
Anyways, the recommended retail price for the 3 devices are:
- Xperia ion: $798 without contract
- Xperia acro S: $698 without contract
- Xperia go: $488 without contract
