TV repair discussion thread (consolidated)
hawthorne
If under warranty just get Samsung to settle the issue. No worry.
Repair status update:
Samsung replaced the screen. Took > 1 week cos they say need to indent the screen from overseas. Returned to me liao watch 10 min now the whole screen screwed up. Whole screen white with a inverse colour image (like looking at a film negative like that)
seebey sian have to take leave get the technician come see again.
Henry Ng
Luckily under warranty. Screen faulty is difficult to do.
hawthorne
ya. but now TV not watchable until the technician comes. At least last time still can watch.
hopefully the technician can fix it once and for all
mep123
Samsung has quite good customer service.call them to replace a new set or refund you $$. They will most likely accede
brainy smurf
Any tv repair to recommend?
My lg tv hdmi and antenna seems not working... I change the antenna cable.. still unable to detect channel after auto scanning..
Sent from Samsung SM-T235 using GAGT
Henry Ng
If Tv still under warranty please call LG. Please also call Mediacorp and their tech will visit u during weekday. Recommended antenna is Funke combo 5.1 la.
brainy smurf
No warranty le.. 5+ years hahah...
Thats why need to access is tv issue or my living room antenna port issue..
Any good repair able to recommend?
Henry Ng
Does your tv has DVB-T2 tuner built-in? If no then a STB is required. To know whether tv or antenna faulty, it is simple. U can call up mediacorp to borrow a funke home 2.0 to see how it is. If can watch mean it is antenna faulty. Nowadays Tv repair is expensive and after sometime other issue may pop up.
brainy smurf
Have... digital ready..
I have used my master room tv antenna to isolate the cable issue.. but fault still persists.. I guess the only way is to bring my master room tv out to test..
ralliart_ray
my 1.5yrs years old Philips 40PFA4509/98 uplorry liao.
The power LED remains RED, cannot display... (cant change to blue)...... despite using remote to power on.... (dont think remote is faulty)
sianz, warranty 1 yr only. :(:(:(
anyone know which part giving problem? :( , how anywhere to sell it for some token sum ?
brainy smurf
How much U bought that time?
hereiam7788
not suprised, P brand is known to make lousy quality product. Their product never last.
Henry Ng
Such part is only available from Philips.
brainy smurf
Anyway for sharing.. I found this shop online..
This guy, Jason is friendly and humble.. he quoted me $200 for repair..
