DesertStrike
guys, u mean the box that holds the router? threw away already... i go check if it is on the router...
anyway, m facing an irritating dlna problem such that after a while router always disappear from selection page, although media is still streaming and running...
anyone facing same problem?
renfred89
Underneath the router will have a sticker indicating the serial number, there you can find the firmware I think.. not sure if my memory has failed.
Have u done a reset after upgrading to latest firmware?
AnTiLooP
Also don't forget to reboot your ONT. I had this problem before and scratching head for a few days then just decide to reboot the ONT and that fixed it.
Gymrat76
After updating to the latest version from Asus website do I need to reset to factory defaults?
hugosantos
Donwload Master
My download master stop working in 3.0.0.4.380_3459
After few minutes stop and generate a log:
Jun 16 11:28:40 transmission-daemon[312]: Couldn't bind port 51410 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
Jun 16 11:28:40 transmission-daemon[312]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:78)
Jun 16 11:28:40 transmission-daemon[312]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:89)
zorrus
Moderator
Moderator
hi all, i am currently on Firmware Version:3.0.0.4.378_5134
is it recommended to upgrade to Firmware Version 3.0.0.4.380.3459 ?
thanks!
PennywisE
Hi, can someone guide me on how do I enable DDNS mode? I seem to have an issue with a private IP. Not sure how do I get pass that despite googling for solution. Help is appreciated :)
MoneyHoney
Can somebody advice me what settings is wrong here?
My android devices keeps getting connected and disconnected frequently.
hawthorne
The WAN IP is a private IP address? If this the case, the only solution is to pay for a public/ static IP
DDNS will resolve to the private IP and u will not be able to access it when u r not connected to ur local lan
PennywisE
I'm puzzled. Meaning to say those with DDNS on this router are all on static IP? I thought when the router says a private IP it refers to that 192.168.x.x
I'm thinking the issue could be due to the way I connect my router. My current setup: ONT -> Switch -> Router.
hawthorne
I thot u say ur wan is a private IP? What subnet is ur wan ip?
The way u connect is wrong also
keels
I updated to 3.0.0.4.380_3459.
Now when i try connect repeater devices ie AC56U or Dir868L to the AC87U's 5ghz band, it is either upload speed slow or no access to internet.
I have set the AC87U5 Ghz to a 2 digit channel number at 40Mhz. Still the same
