deathblade82
- Oct 25, 2002
anyone knows what is the version of the default firmware that comes with the router?
Look for the white label underside or from the box itself ?
guys, u mean the box that holds the router? threw away already... i go check if it is on the router...
anyway, m facing an irritating dlna problem such that after a while router always disappear from selection page, although media is still streaming and running...
anyone facing same problem?
yup, i did...
Did this problem occurred before or after firmware update ? If after, try going back to the last version.
Hi, can someone guide me on how do I enable DDNS mode? I seem to have an issue with a private IP. Not sure how do I get pass that despite googling for solution. Help is appreciated![]()
Can somebody advice me what settings is wrong here?
My android devices keeps getting connected and disconnected frequently.
The WAN IP is a private IP address? If this the case, the only solution is to pay for a public/ static IP
DDNS will resolve to the private IP and u will not be able to access it when u r not connected to ur local lan
You should enable Reducing USB 3.0 interference if you are not connecting any hard drive to your router.
I'm puzzled. Meaning to say those with DDNS on this router are all on static IP? I thought when the router says a private IP it refers to that 192.168.x.x
I'm thinking the issue could be due to the way I connect my router. My current setup: ONT -> Switch -> Router.
I thot u say ur wan is a private IP? What subnet is ur wan ip?
The way u connect is wrong also
