zorrus
Moderator
Moderator
my android phone will auto disconnect from my 5G wifi when it goes idle, and reconnect when i start using my phone again.
i did not have this issue with the normal 2.4G wifi network, any tips on how to resolve this issue? thanks!
DesertStrike
guys, Asus ddns can only be use on USB device?
if i have my own NAS, i would not be able to use asus DDNS?
sentinelvdx
Yes, ASUS DDNS will publish your public IP, then you have to put the port forwarding rule to point to your NAS LAN IP, so you can access it from Internet.
winner22000
May I know why my 5Ghz showing 802.11n instead of 802.11ac? I am using windows 10 and how can I make it work? Thanks
Gymrat76
When I went into the router home page, I saw a popup asking to upgrade the firmware to 3459, so I clicked OK.
After the firmware update, the GUI is completely in Japanese! The language tab on the upper right is missing as well. (got the router in Japan last year).
I tried downloading 3459 from Asus Singapore and reupdated it again, but no difference, it's still in Japanese. Any idea how to get it back to English? :s13:
localITguy
Suspended
wah.
ASUS New fw no QC one, always fk things up. i think it best not to update LOL ( look at the AC88U Thread)
export set ah?
i think cuz the default is set to jap.
what you can do is put the router into res mode and upload the SG Version via the Windows rescue tool ( included in your CD for the router or you can download)
set your PC ip to 192.168.1.10 and default everything . connect the LAN Cable from your PC TO the router Only (remove everything else)
Press the power button to turn off the router. Keep long-pressing the button [Reset] about 5 seconds. If the power is flashing, the wireless router is on rescue mode. Open -[Firmware Restoration tool], click [browse] and choose the latest firmware which you had downloaded and click upload, and wait for it to upload finish
if still cannot, you flash back the jap version via the tool and see if you can change to english from there
Hope it helps
Gymrat76
wah.
export set ah?
Hope it helps
Thanks man.. I will copy these instructions for later. As I don't really go into settings to tweak my router settings very much, I'm content to leave it for now and to see if perhaps a newer version will address the language issue. :)
xonix
I recall there's a change language button near the top right hand corner in the main menu. Maybe your can try that before flashing ?
Gymrat76
Nope.. it's missing :s13:
xonix
[img ]http://i.imgur.com/wwWydsT.jpg[/img]
Oops.. you should try re-flashing a firmware from the Asus sg website then. Hopefully, it will solve the issue.
I stopped updating mine after 9529 because it was no longer giving me problems.
Gymrat76
If you see my post above, that's what I did.. downloaded from the Sg website and reflashed but it was still the same. Will try localitguy's method if I need to at some point, but for now will leave it and see if the next release fixes the problem
xonix
Fingers crossed it works for you. I usually prefer to read the change log before any updates. So, I downloaded mine from the asus sg website and updated manually. Don't trust the web update mechanism.
IIRedsunsII
has asus give up on this model already? Wifi connectivity is still keep dropping and not stable.
Really regret paying $300(ard this price cannot remember) for such subpar performance. /sad
Think i will avoid asus brand for network for future purchases...:(
sentinelvdx
No, they didn't. In fact branch 382.xxxx is on the way so wait for it.
xorionn
My AC87U (near the ONT in my living room) is giving me problems as well - It's on the latest Asus firmware 380.3459.
My desktop is my room using a TP-link T4UH USB wifi adaptor keeps dropping it's connection to the 5Ghz. 2.4Ghz not so much dropping.
How do I fix this? :(
