Official MIO TV Thread.......
renfred89
Hi,
1. Is Singtel silver set top box full HD? 1080p? I just upgraded my HD ready TV to a full HD TV but I do not see the 1080p screen resolution in the settings.
2. Is there any way I can change to a new set top box? I find that it is lagging especially when compared to the new set top box I experience in my friend's house.
1. i think only on 1080i.
2. different models come with different features, such as DVR etc, depending on what the services you signed up for. you won't be able to replace the set top box unless its deemed faulty. the motorola set top box is slightly laggy, but won't be that lag to the extend of frustration leh.
WestGuy
Hi,
1. The Silver Motorola one can only output 1080i at best. The black Cisco one can output at 1080p.
2. I had my silver Motorola one exchanged to the black Cisco one.
NikNikNik
Hi anyone have problems with the loading is almost done screen? I just bought a new asus router. I got singtel tv to work yesterday but realised today that my wired connections are not online. So i off and on my router and modem. After that singteltv cant see. I already tried to off my tv box and modem and on back but no use. Internet everything is working fine.
renfred89
You need to be more specific in mentioning your problem leh..
renfred89
Singtel tv can't start. Stuck at the "please ensure is connected to modem... almost done loading" screen.
check if the cables are properly connected.
if not, make sure you start the equipments sequentially. meaning from ONT to router then singtel tv set top box..
NikNikNik
Hi I found out the reason singtel box cable needs to go go lan port 4. =_= voip to go to port 3. After plugging in lan cable to port 4 it worked. I kept port 3 unused though.
renfred89
If that's the case, likely you have selected singtel-mio profile. You should be selecting singtel others profile so that port 123 can be used for LAN devices and port 4 for singtel TV.
NikNikNik
Is there a need to reset up connection again? Is ok to leave it as singtel-mio profile just that port 3 is unused? My port 1 n 2 are currently being used for lan devices. Port 4 singteltv.
renfred89
No issue with that. You don't even have to reset the router if you wanna change the iptv profile. The router will simply just reboot and be up in less than 3 minutes.
You may just leave it if it's not a hassle..
red_viper
Volume on AV amp down
After recontracting, I opted for a new plan/modem that enables recording. The first set had a problem. Changed to new one. Now, whenever I change channels, the volume on my Yamaha AV amp keeps going off. I need to switch off the modem and/or amp to get back the sound from my amp. Its also the same when I switch hdmi ports on my tv. Switching from a port for my iptv set to the set top box will cause a loss of volume on my TV! I have to switch off my TV. During the visit by Singtel techician, I was advised to chnage back to the old modem, ie without recording. The problem is whether I can change the plan I signed up for!
renfred89
wow. this is bizarre.
its gonna be difficult to diagnose this issue on this platform. perhaps lets start from the ground.
State your set top box model?
secondly, audio and visual from set top box should be carried by HDMI right to your tv? is it ok you shoot a picture of your set top box connection? just take a snapshot of whats connected will do.
thirdly, which router were you provided?
yodaiam
Cisco ISB 2200 Infrared
Hi,
Anyone has any idea which infrared (remote control receiver) frequency range does the Cisco ISB 2200 operate on?
I've tried to use a IR extender that operates in the 34khz-60khz and it does not seems to work.
Could it be using the RCMM?
Any information will be greatly appreciated.
LeSaux
I'm using a Philips TV and suddenly yesterday there was no sound only picture on the TV. Am using Singtel TV on fibre broadband.
Anyone knows if it's HDMI cable problem or Singtel broadband issue?
renfred89
If you can use Internet, then it's not a broadband issue.
Try to change to another cable first?
If not, check your volume settings..
Norman Chan
Like to check with you guys , how is your Singtel TV performance , starting from last month , always encounter video lagging whenever switch on and need to change to other channel than switch back and forth a few times than the channel stable down but maybe after watch about 45 min to an hour , the video lagging problem surface again.
renfred89
are you using the default singtel tv router? which model is that?
which set top box is that?
for me i had used singtel tv before i hopped onto the unlimited fibre wagon, my experience was so far so good. I wasn't using the default singtel gateway though, so perhaps the router might have an impact on the streaming experience.
Are you on ADSL? i had major stability issues and just got the tech come down he changed to a new modem + touch up the phone line a bit! Dunno got do firmware update of the stb but only after this most recent servicing then ADSL MIO is smooth :s22:
