Mechanical KB information
zephyr11
nice and sharp, ordered a set of keycaps from TB, can't wait for it to come. my work kb needs a new set SOOO bad...
ragnarok95
Senior Moderator
Senior Moderator
Sucks... forget leopold and filco using diff type of key caps. :( :(
AlvinDj
Finally... Took the plunge yesterday @ Xtreme Solutions after kena poison...
Bought the Filco MT Red switch... Since Ducky Shine 5 no stock... Apparently Shine 6 is coming out soon next year..
Now might want to change a few key caps... Can anyone recommend where best to get keycap for Filco via Taobao? What brand / model etc?
xSieghartx
Just ordered the Taihao Miami PBT keycaps. :D
https://world.taobao.com/item/532095738412.htm?fromSite=main&_u=h2fbk2q12436
Photo taken from listing.
trenzterra
Npkc has some pretty good ones.
ZrE0_Cha0s
nice? that kb? got pic?
ZrE0_Cha0s
can search TB for keycaps, but be ready to spend hours upon hours staring and searching. IT NEVER ENDS.
just to share, my TB order just came in. :D:D:D
IMG_2377 by chewyicecube, on Flickr
IMG_2376 by chewyicecube, on Flickr
IMG_2375 by chewyicecube, on Flickr
that color is nice though. corner full purple and slow turn into black :D
but the kb looks kinda weird though.. double space bar and below still got some function key...like what is this kb?
AlvinDj
That's the problem you see! I don't want to spend too much time on TB chasing over key-caps because I will be in a huge dilemma and I needa use google translate..
I rather someone just direct me to a certain few awesome brands and I just grab :s13:
Come bro.. SIC some links that you bought from?
ragnarok95
Senior Moderator
Senior Moderator
What are you looking for? If you need from A-Z, can buy from my minila seller.
AlvinDj
I don't mind full A-Z actually or maybe just a few like WASD / ESC / Space / Enter etc..
I'm quite open to choices but main thing is the key cap must be solid built, wont fade so easily and able to fit Filco MT2
Can SIC me the URL you bought from.. ?
Darknights
And the difference of PBT vs Double-Shot?
I have always heard of PBT keycaps... Seem to be the renown mainstream keycaps..
PBT is the material use.. which is tougher to get oil stain.
double shot is how the keys are "printed". so instead of just printing them on, they are created out of mold using 2 distinct plastic parts to form the letter. hence, it'll last "forever" and won't fade.
there are many different keycaps manufacturers around. notable ones will be signature plastics and GMK. most of the nice looking keyboards you see online, are probably from either of these shops. however, they are damn costly - probably cost more than the price of your keyboard.
tai hao and the ones from taobao are cheap and good, which you can buy and swap to your heart's desire.
zephyr11
this is actually the tray that they use to send the kb, so it's actually a complete set that includes options for TKL, 60% or those funky sizes.
Darkknigths;
yea, pbt, quite sick, I haven't had time to install it yet though. will try to sort it out later.
AlvinDJ;
you got your answer above. very good explanation about what is what and where to get what.
