Poly Laptop Roadshow
Intrinion
Senior Moderator
Senior Moderator
The dust though. Time for alittle cleaning :zotto:
My mother has been using this as her backup drive for a few years and it has been reliable. Not sure about their smaller ext hard drives though.
imshleep
I'm waiting for the nyp roadshow. I'm just referring to the Rp site as nyp has not updated theirs yet. We have to wait for nyp, sadly :sad: .
p.s. what course are u going to?
Multimedia and infocomm tech. So its every poly also same laptop? But nyp one so late ),:
Bilal N
Ooo thx . Will be going on the 17th
The asus UX310 has the gtx 940MX instead of the gtx 930MX on the Hp, which will allow u to do more graphics intensive stuff(higher game settings).
As for the diff between 3200x1800 and full hd, honestly at 13-14 inch screen size it should not be too different to the naked eye.
But I still think u should go down to the roadshow and look at the laptops in person and make a decision based on what u feel. That way u will have min regret instead of making decision now then regret later.
RiceGrain
Actually if you are already enrolled, with your student number etc you can purchase it online
www.asiapac.com.sg/rp <-change rp to your respective poly to see the pricelist, there are 2 different pricelist
Jedixx
That was the first thing I checked, they have not yet updated it on nyp, tp or sp. It still shows last year model.
Jedixx
Anyone here from np that already got their laptop for a few days already? If so, which model did you buy and what are your first impressions of the laptop?
Thanks in advance for sharing.
Bilal N
2 of my friends bough GL533.performance wise pretty gd but they said its heavy la.Gna hv a hard time bringing it around since its a gaming laptop mah
jack27
How much from those retail shop for the same spec same brand or other brand?
• 7th Gen Intel® Core™ i7-7700HQ Processor 2.8 GHz
(6M Cache, Turbo Boost up to 3.8 GHz)
• Windows 10 Home
• 15.6" AG FHD Backlit LED (1920 x 1080)
• 8GB RAM; max. 32GB
• 256GB SSD
• NVIDIA® GeForce® GTX 1050, 4GB DDR5 Dedicated Graphics Card
Jedixx
• Windows 10 Home
• 256GB SSD
retail should be slightly lower in stores but there you go. 2.1k SGD
zensushi
Moderator
Moderator
VivoCity has Best Denki (I think) atrium sales. Saw one with similar-ish specs but with 1050 Ti @ $2300+, if I am not mistaken...
Jedixx
That should be the GL553 with 1080 Ti
Edit: I meant 1050 Ti not 1080 Ti
