Wireless IP Camera thread
guile
lQZGk7FcIVXyDdRFHhq5pAK2SB9pm9Z1Agt35fVA4nw
JLPE5EZYlkpmLBCZXC0t1eOPGM-piiQZx8dCTc9Sd6Y
So my PT528V is showing these artifacts recently.
I tried to email support@sineoji.com but the mail got bounced as their mailbox is full.
Anyone have Dean's number so I can contact him? This happens even after restarting the camera.
FinchGuy
Have a Sineoji PT331V but can't view using my mobile. Keep getting a "Error in connection log" message. Uninstalled and reinstalled the viewer app and reset the cam using the button in the base but still can't use the viewer. Any suggestions? Thanks for any help
localITguy
Suspended
did you set the password correctly?
reset, and add the camera and set a new password.
anyway, you should contact sineoji for help.
JakiBOii
For the ease on installation, I suggest getting the Canary cameras. They don't look like camera's at first glance. This info might help. Though they will require a monthly subscription for storage.
goodwin
You have entered the wrong password to the camera. That's the reason it is showing error in connection log.
evilster
Hi everyone I have a sineoji IP Camera,
Recently I realised the device keep going offline even though i can scanned the presence of it when i try to remove and add the device. May i know is there any way to prevent it from going offline. I can't use it at all? Any advice?
localITguy
Suspended
should contact sineoji, sounds like a faulty unit
:eek:
monfrisco
Is you camera ID starts with WXH or SXH ? If WXH, please upgrade firmware.
furryballs
Same here. Only started last weekend. I suspect is their server host got problem
Dave27
I just checked 4 of my Sineoji cams. Starts with SXH, all online.
Using M1 4G mobile data.
furryballs
Sian sineoji cams disconnected. I will just buy another brand to replace. Unreliable sia
endrue
Dean,
Please fix this if you read this forum. My 3 cam sineoji not accesible using 4G... notice for the last 2 days..
DELTAFORCE
Dean,
My 2 PT528V also having the same problem for the past 2 weeks. Tried restarting router and camera but still having the same issue. Dean, please rectified this connection problem asap.
Thanks
:s12::s12:
monfrisco
Hi everyone,
We are in the midst of upgrading the Sineoji server in 2 phases. Some will be affected. It should be completed by tomorrow and we will conduct a final checklist before it goes live.
Thanks for your patience and apologize for any inconvenience caused.
furryballs
Hi everyone,
Still offline intermitten. Need to tap many times before can connect
monfrisco
Hi everyone,
We have completed the upgrading of the Sineoji server at 935 pm, 8 Oct 2017, this evening.
Thanks for the support and patience.
pozidrive
hi. I just bought the PT713V. One key keeps telling me search failed. restarted everything including my router. Please help. TIA.
