Vios owner group
BuGGi3
hey bros
avante, lancer or vios :(
budget ard 25-30k
You come vios group we recommend vios :s13:
I think all 3 listed is fine, if you can find one with better condition, whack lo! but toyota, can never go wrong ba.
Scherzinger
Yeah Toyota reliability no horse run this one I can't agree more!
Scherzinger
Vios for fc and slightly cheaper road tax
Avante for space
Lancer ex 2.0 for power, 1.5 don't bother
2.0 petrol too chor I can't afford :(
Yeah 1.5 quite lack the power
Guess it's down to avante or vios
But avante should be cheaper right
BuGGi3
Haha no la 30k is the valuation of the car :s13:
Jazz too small for me I quite tall ard 184
Wah you are really tall!
Use elimination method. Back then I was deciding between Jazz, Lancer CS3, Altis, Axio & Vios.
I struck out Jazz because i'm really worried about gearbox issue. Then struck out Lancer CS3 (those EX lancers haven't expire back then ma) because i'm mostly worried that it can't fit in a 2din headunit :s13:.
Then comes the Toyota fight. Axio, heard some scary CVT gearbox issue that it just die without symptoms, so out! Altis (E120) & Vios (NCP42), back then my thoughts is that it looks oldie, so out! (But damn... 42s can look really good with mods & it's super damn reliable).
Chanced upon one and got a Vios NCP93 in the end. Likely the very first batch ba! Since i saw some SGU carplates which are 42s. Am happy with it ;)
EJB
Based on your 3 choices, trust me, Vios is the answer.
Archuke
Cvt transmission is actually quite bulletproof. Unless you anyhow shift like racer with that transmission. It should last very very very long.
keithchan
Started driving a 07 Vios since 2 months ago.
As compared to my previous Fiat Punto this car is a real no frills, all rounder value (for the price range).
Decent FC, powerful air con, ample sitting room, reasonable boot size.
Only feel the car's too light and floaty at >110km/hr but it's probably not built for that kinda speeds; at least in stock conditions.
All in all I'm very pleased.
BuGGi3
Consider aftermarket rims & lowering. Had a good run on NSHW few months ago at 90% of speedo.
EJB
You can do two things, add an engine bay 2 point strut bar, and also lower the car. Thereafter 110km is nothing ;)
keithchan
May consider the strut bar but definitely not gonna lower or do coils.
Mostly with kid these days and comfort is priority.
Just sometimes alone in JB and I'll push to 130km/h for a fun sprint.
EJB
Depending on the right coils, your comfort won't be sacrificed :)
BuGGi3
Engine bay strut bar without lowering is like no effect actually, cuz I'm currently on this setup :s13:
BuGGi3
90%!!!? With a Vios!
YOU HAVE BALLS.
:s13: don't think that i'm the only one. i'm sure there are many others running BEYOND that speed hitting 100% with Vios.
Only if you're confident with your setup and vehicle condition. 1st thing to change out will be that 5.5jj stock rims.
BuGGi3
Consider a set of good tires in JB! RE003 is good, each is only about $70+ for 15" there.
