Singtel Wifi Gigabit Router AC1900! (Arcadyan)
THFC78
For those who are using this router, do you all enable band steering?
amazingone
Not sure if it normal, but my wifi speed drop to around 80 Mpbs when i disable it. Before that was in 200 mpbs range
I didn't test for my speed when I have band steering on, but my typical speed on WiFi with band steering off is around 110Mbps.
renfred89
Band steering steers the devices into bands automatically, which it might have allocated 5Ghz for your device. 80mbps is likely due to 2.4Ghz.
You might wanna Change your ssid for 5Ghz which is different from 2.4Ghz so that your device don’t get confused with 2.4Ghz.
kw442
Mine is something like:
ABC-24
XYZ-5
so I can tell which band easily.
THFC78
oh no wonder, thanks for the clarification. I must say the 5 GHz signal coverage for this AC router is pretty decent as compare to my old singtel router model where I only manage to get intermediate connection nia for 5 Ghz
kw442
I presumed speed tests are done using wifi.
Using 2.4 GHz or 5 GHz?
Too many parameters/variables & what's obvious to u may not be so to others.
amazingone
Asking for a fren with singtel 1Gb fibre plan n mio TV...
misery starts when singtel took back the old router....
current setup: Ericsson ONT, AC Elite (AC1900)....
ONT > AC Elite
> LAN 1 MioTV
Sitting right in front of router with S8/i6/i7, did a speed test: 84mb down/44mb up...
pls dun give those thick-skulled singtel cso's scripted replies... reli enuff of their crap...
:vijayadmin:
Is band steering turned on for the AC Elite? It could mean the devices are connected to the 2.4GHz channel.
tungsten2
ONT > AC Elite
> LAN 1 MioTV
pls dun give those thick-skulled singtel cso's scripted replies... reli enuff of their crap... :vijayadmin:
fussier and savvier users, recommendation is to manage the networks yourself and ensure that your performance-critical devices are connected to the faster 5GHz network.
Sent from Samsung GT-N5120 using GAGT
orpisia
High Honorary Member
using the supplied singtel ac plus router, 380+ down and 400+ up. is this considered noob or average for this router or what? from singtel to singtel on speedtest, am on 1gbps plan
dryteletubby
wireless nia, 1gbps...lousy is it the speed?
WIFI depends more on your device you testing on, interference, and obstacles around your house.
your speed is probably normal. You are not going to get 1gbps out of WiFi
renfred89
like what dryteletubby had mentioned, those factors and the type of wireless device you have plays a part.
maybe can tell us what device you use to test, so that we can roughly tell you the peak speed of it?
orpisia
alright, noted
asus ac56 pci-e
