YouHeypiCanLiao
- May 11, 2017
Yes, Digi Best prepaid has inactive/passive period of 75days...
If your Digi Best prepaid's validity is till 11th Sep 2018 -- that means your Digi Best prepaid is active till 11th Sep 2018.
After 11th Sep 2018, your Digi Best prepaid will become inactive/passive.
Inactive/passive period will be 11th Sep 2018 + 75days.
In this case -- inactive period will be from 12th Sep 2018 to 25th Nov 2018 (11th Sep 2018 + 75days ==> will be till 25th Nov 2018)
On 25th Nov 2018, if you extend/renew validity by buying RM1 SLL (Super Long Life), your Digi Best prepaid will be active again for 24hrs (1 day) -- till 26th Nov 2018.
After 26th Nov 2018, your Digi Best prepaid will become inactive/passive.
Inactive/passive period will be 26th Nov 2018 + 75days.
Is the above clear enough?
Also -- ANYTIME (during inactive/passive period) if you reload/top up -- your Digi prepaid will become active.
Each RM1 you reload gives you 1 day active for the Digi prepaid.
If you do a single reload of RM5, you get 5 days active period for your Digi prepaid.
If you do a single reload of RM10, you get 10 days active period for your Digi prepaid, etc.
Note: the active period you get on your Digi prepaid for reload -- does not stack.
Yes, you can extend/renew validity on the Digi prepaid by buying the RM1 SLL when in Singapore
You can buy the RM1 SLL either by:
(1) Using USSD code.
(2) Using the Digi app.
Refer to a post I wrote (some time ago in this thread) about paying RM1 to extend validity on Digi prepaid via USSD code HERE:
https://forums.hardwarezone.com.sg/105692913-post4699.html
The service to deduct money from Digi prepaid card balance -- in order to PAY & BUY active/validity period is called SLL (Super Long Life).
Refer to a post I wrote (some time ago in this thread) about Digi prepaid SLL (Super Long Life) HERE:
https://forums.hardwarezone.com.sg/105695966-post4701.html
Extend validity by buying RM1 SLL is just paying RM1 to buy 1 day active period for the Digi prepaid -- you're not buying any data.
AFAIK, (As far as I know),
From 2017 onwards, newly bought Digi prepaid SIM cards all comes with FREE basic Internet.
That means, if your Digi BEST prepaid comes with FREE basic Internet, you have FREE Internet access (at slow 64kbps speed up to 500MB/mth) -- without the need to buy any data plan.
If 64kbps is too slow for you, you can always buy any Digi prepaid data plan.
You'll have 4G/LTE full speed Internet after you buy (any) data plan on your Digi prepaid.
You can buy data plan for your Digi prepaid either via USSD code (*116#) or via the Digi app.
(Internet speed on the Digi prepaid will revert back to slow 64kbps once the prepaid data plan you bought expired or you used up the mobile data quota in the data plan.)
Note: You can only access Internet when your Digi Prepaid is active !!
Even if you buy data plan during inactive/passive period -- you cannot use the data plan (or use the FREE basic Internet) to access Internet on the Digi prepaid.
You can only access Internet on the Digi prepaid once it is active.
Both Digi BEST & Digi Live prepaid has respective pros & cons.
Which is "better" depends on your usage requirements.
(Since this post is getting long & tedious, I'll refrain from discussing the differences between Digi BEST & Digi Live prepaid here.)
It's best (pun intended) you go find out the differences between Digi Best & Digi Live prepaid -- and decide for yourself which one suits your usage better
Digi BEST prepaid no longer seems to be listed on the Digi prepaid Web site:
https://new.digi.com.my/prepaid
So not sure whether Digi BEST prepaid is still being sold or not.
Back to the issue of buying RM1 SLL on the Digi Best prepaid...
Personally, if I need to buy RM1 SLL -- my habit is to try & buy it on the inactive period 74th day -- instead of on 75th day.
Why?
If I'm busy & forget to buy RM1 SLL on inactive period 74th day -- I can still buy the RM1 SLL on (next day) 75th day.
If you're busy & forget to buy RM1 SLL on inactive period 75th day -- then you can no longer buy RM1 SLL on (next day) 76th day.
If no reload/top up done or no SLL purchased within 75 days inactive period -- on the 76th day the Digi Best prepaid card will be terminated.
Hope the above helps.
Can explain to me why sometimes when I re-load RM10 when my SIM is inactive ( within 75 days ), it will auto use up the RM10? I think it auto sub to some 7 days sub.. how come ah?
