Singtel 1 Gbps Fibre
uncle_josh
You using ONT or ONR ?
868L does not support Singtel vlan tagging
Sent from 当断不断, 害人害己 using GAGT
uncle_josh
The ZTE brand function as a ONT. If you use 868l, you will need to add a manage switch after the 868l router.
It is more advisable if you use those router that supports vlan tagging and set the profiles .
OKorNOT
So u mean it cant be use it as a direct router?
And wad is a manage switch??
Sorry i noob
Sorry i noob
The ONT needs to be used with the SingTel routers or 3rd party routers supporting VLAN function.
Since you are not familiar with this type of stuff, better buy the SingTel AC1900, AC Elite, AC Plus from Crousell at price around S$10 to S$40. AC1900 and AC Elite are basically the same, AC Plus is of lower speed AC1200 class but it is newer than AC1900/AC Elite.
Anyone know how to connect singtel fibre to 3rd party router?
I brought a dlink 868 to replace my faulty singtel ac 1900...
Can connect to ssid with signal but no internet access...
BTW, are you still on contract with SingTel? You can contact them for one to one exchange at Serv+ if that is the case.
If you are out of contract, not so sure...
uncle_josh
The vlan setting in 868l router page still missing the priority settings.
Hence cannot be used for Singtel.
OKorNOT
if no priority setting, can use for broadband but not singtel tv..
I only need the internet, i dun hav mio also...
There also 4 more option
1.wireless router
2.access point
3.brigde
4.cant rmb haha
So i hav to choose 1 right
OKorNOT
Later go back will try again, so complicated to setup a 3rd party router for singtel....wasted dunno how many hours alrdy messing with the setting still cannot get internet...
If still cannot i give up liao no energy liao
OKorNOT
Went to singtel shop at amk hub to enquire about recontract lmao
Say no new router will be given, only 2 more years of warranty will be added to ur current old router after recontract and 49.90/mth for 1gbps,currently i m on 59.90..zzz..only 10 discount wth
Think i better look for a new telco for my internet
https://www.singtel.com/personal/products-services/broadband/fibre-broadband-plans
Website still shows S$44.90.
As for the two year old warranty, it means you can do one to one exchange at Serv+ in the contract period.
Singtel
Suspended
Hi OKorNOT,
There is currently a Christmas promotion for Singtel 1Gbps fibre, if you re-contract by tomorrow, it is $41.90/month.
You can sign up here, or call 1688.
Thanks.
daylight
Hi OKorNOT,
Thanks.
i did a re-contract for the 1Gbps fibre on Monday afternoon, when i went home found my internet down since down.
i am using 3rd party router from netgear.
router shows no internet traffic, icon is red.
called singtel support, they advised me to take the singtel router and try
my ONT is the old black one from ZTE.
using it since 2013 when i was on 500Mbps.
my previous plan was fibre unlimited
renfred89
Any red led from ont? We’re u using clan profile before the recontract?
Tried a reboot?
