- Sep 16, 2018
i did a re-contract for the 1Gbps fibre on Monday afternoon, when i went home found my internet down since down.
i am using 3rd party router from netgear.
router shows no internet traffic, icon is red.
called singtel support, they advised me to take the singtel router and try
my ONT is the old black one from ZTE.
using it since 2013 when i was on 500Mbps.
my previous plan was fibre unlimited
Your old plan (1Gbps Fibre Unlimited) does not need Vlan settings. And that is under the other thread.
Are you now changed to the normal 1Gbps plan? In that case you need to configure Vlan if using with ONT. You need to check with the Netgear site to see how to configure Vlan.
Interestingly they did not give you the Huawei ONR.
