- Mar 22, 2011
No email yet
A few of us here got the email few days ago, you might want to find your junk or spam mail. Which plan you are on? uno or Uno18?
No email yet
Oh, I m on the new $10 plan on M1 network. My spam folder is empty
so if we are overseas, the MyRepublic Talk app will allow all incoming call regardless of what country to be deducted from the local talk time that we have, and if we were to call to Singapore they will just charge at 5¢ per minute?
Oh, that means this is not for you. Don't worry. I got the email for maintenance is because I'm on old starhub network, I'm using the old Uno plan.
Anyway, how is the speed going on for you, and are using VOLTE for your voice calls?
I'm getting fantastic speed. Tested inside home:
Nice, good to have Volte. Yeah, your speed test very similar to M1.I have a main line with M1, no complaint, since I don’t use much data while on the go.
Speed wise MR is similar to the original M1.
Speed test at my front door with MR. Indoor will be slower. You can see the VoLTE on the screenshot.
Yes, you are right. But take note, when overseas you have to use the MyRepublic app and connected to either 4G or wifi. If there is no internet connection, it will be charged at a normal rate. Also in the app, you have to enable mobile forwarding.
thanks. so actually can also buy a tourist sim card and it will also work the same right. cause some of their data roaming rates are not very good.
Reason for not signing? For those who hate or don't like using M1 Network.
Thanks
Used m1 before years ago. Dont remember any issuee. This MR $10 plan loooks good
I am using singtel nowNo issues with M1 network. What telco or MVNO you using now?
My secondary line using old Myrepublic plan using Starhub network. I can say it's bad on starhub. I'm glad that they made the switch to M1 and my primary line is using M1.
Dont know if will feel a "downgrade" going to m1
For MR is there overusage charge for outgoing calls? Or once hit quota cant call anymore
Nope, you can't change UNO plan to this $10 plan. This is due to technical constraints, as old customers are on Starhub, and new plans from 31 March are on M1 network. They are still looking for workaround to switch customers over to M1.I have an old UNO plan, can I update to this $10 plan? There is no option on the app. Also it will be better if the app can handle 2 number under the same name as I have 2 lines.
