Official MIO TV Thread.......
zensushi
Moderator
Moderator
Guys i sign up for mio tv online. How long will take for installation. The6 say they will contact me
I received the call yesterday (Monday) & (re-)signed up for the subscription. Was promised delivery & installation on Thursday.
dinosaur2776
Guys just wanna check.
Any feedback on using singtel cast to watch bpl. Reliable?
And i own a samsung smart tv and xiaomi box. Can i install the app there?
Yes you can install SingTel Cast on Samsung TV or Mi Box S.
I have Cast subscription for Entertainment pack but no Sports Plus ( EPL) pack as I do not watch soccer.
There were negative feedbacks previously about buffering and frame skip. Not so sure if the situation gets better now.
Fibre TV is still more stable.
sleepingfox
RT-AX6100 on MioTV
Hi guys,
I've recently bought a ASUS RT-AX6100 and i am having some issues setting it up with my MioTV. I have tried the 'Singtel - MIO' and 'Singtel - others' option on set up and it doesn't work.
Anyone has any insights on this?
Thanks much
Hi guys,
Thanks much
This RT-AX92U Mesh does not seem to be popular in this forum. Zen WiFi XT8 seems to be more popular.
I will suggest you to check with Asus Technical Support.
sadboy
Hi guys,
Thanks much
BTW u using ONT or ONR?
josh_ong
May I know which port are you using for MIO TV? I intend to get this router after seeing you able to make it work well.
I have been using an ASUS RT-AC5300 for many years now, with Singtel Mio TV.
Excellent WIFI coverage for the entire household.
No dead wifi zones anywhere.
I highly recommend this router, if you are thinking of making the switch.
BTW, I have 2 Singtel Mio TV set boxes in my household, and my router can natively work to support both.
P.S. I received a PM about setting up the ASUS 5300 Router to support 2 SingTel Mio TV set boxes. I am making this information public to anyone who might need it. :)
HARDWARE SETUP
First of all , you must have an existing working setup with the 2 Mio TV boxes and the original supplied SingTel router .
After you replace the SingTel router with your ASUS router , you have to login into the ASUS router.
ROUTER SOFTWARE SETUP
Under LAN , Tab IPTV,
Select “ Manual Setting” for ISP Profile.
Use these settings :
Internet : VID: 10, PRIO: 0
LAN Port 4: VID: 20, PRIO: 4
LAN Port 3: VID: 20, PRIO: 4
DHCP: Microsoft
IGMP PROXY: Disable
IGMP Snooping: Disable
(Udpxy) : 0
Usually there is a preset for SingTel Mio TV and you use LAN port 4.
He has two Mio TV Box (now Mio TV is called SingTel TV) so he uses manual settings to use LAN port 3 and port 4 for SingTel TV boxes.
DHCP: Microsoft
IGMP PROXY: Disable
(Udpxy) : 0
josh_ong
Oic. Thank you
DHCP: Microsoft
IGMP PROXY: Disable
(Udpxy) : 0
josh_ong
Oh yea. I realised this AcRT5300 router does not have digital voice for home phone. If I am looking at this router, so I must link my Singtel Router to Ac5300 if I wanted the digital voice?
My tv kept freezing none stop until I am so annoyed now. Thought I have chance for tv but now must think of home phone.
No, you can ask SingTel to move the digital voice to the ONT.
I did that in April 2014 when I changed from Singtel provided Pace router to my own router Linksys WRT1900AC.
josh_ong
That's great! Thank you for sharing. Really appreciated.
Now I can get the new router.
May I know how much is retail for Ac Rt5300? I saw so many ppl selling at carousell with different pricing.
Knightoftheblackrose
My SingTel package came with a free Digital Phone line .
My phone is connected to the SingTel ONT box.
Hope it answers your question.
No idea on this Carousell as I do not really use Carousell. And I am not good at finding lobangs.
RT-AC5300 is a high end router (Tri-band AC router), so depending on the price you find out, you may want to consider other routers like RT-AX88U (dual band WiFi 6 router).
uncle_josh
RT-AX88U is old and problematic.
There is a thread dedicated for it.
mai lah, sure regret .
Sent from 天作孽 犹可恕 自作孽 不可活 using GAGT
