TV repair discussion thread II [consolidated]
Jerry2358
Samsung UA55JS9000 cooling fan issue
Hi Bros, I encounter a problem with my Samsung TV, UA55JS9000, it says problem with cooling fan. anyone got kena before or know any solutions? It will auto switch off after few mins...
limtk55
Just dismantle and clean up the dust/grime clogging the fan and it should be ok. No big issue here.
i1magic
Hard to say. Only proper troubleshooting will tell what is actually wrong and whether it is worth fixing. TCON is a likely candidate though, so is the mainboard, scalar PCBs and flex cables.
So for proper troubleshooting, will probably cost $50 or more just for the labour of troubleshooting by uncle Ho?
Wah, if mainboard or scalar PCBs or flex cables got problem, buang already right? Because the parts will cost >$100?
Xiaomi Mi TV 4S 65 inch 4K HDR LED TV was going at $720 (inclusive of delivery) last week.
i1magic
Anybody know what fault is it?
I suspect this is T-con issue.
When I play YouTube videos, I can hear the sound and can see the pictures. Just that there will be a lot of horizontal lines. If I were to move back further away, the picture quality appears more watchable.
kenzie
My Panasonic LED tv can’t turned on. I switch power off and on back there are no red standby light. What is the problem normally?
prof_tan
call helpline, they can tell you initial assessment cost... think they quoted me 180 last month, not yet inclusive of boards to change.
maybe connect Bluetooth speaker will be better option
limtk55
Anyone ever had their samsung tv only the audio stops working? What's the repair cost like?
2 possibilities is either the speaker has blown, or the speaker controller ic has malfunctioned. Do you usually put the TV volume quite loud while watching?
limtk55
Usually the powerboard. But cannot rule out related components too. Need to troubleshoot in detail. I've repaired TVs with the same symptoms and the culprits turned out different each time.
cscs3
Power board gone case.
Search the model in TaoBao or Aliexpress see if there is part selling there.
Stiletto
Recently, when my TV is on, I heard a quite loud popping sound a few times. But the TV was still running fine.
At first, I didn't know where that popping sound came from.
Was left scratching my head.
Until this morning, when I was turning on the TV, I saw a bright spark and popping sound from the TV plug or socket. Not sure it came from which. Only then, I realised the popping sound I heard before came from this.
After this, the TV could no longer turn on. Even though before this, despite the popping sound, the TV would still run.
Tested the socket by plugging in another electrical component. A media box. It is running well with no problems.
Used the power cable from the TV that is unable to turn on, and used it on another TV. The TV running well too.
So am I right to say the problem is probably with the TV and not the socket or plug? But strange thing is, I saw the spark from the plug.
cscs3
Looks like tv power supply is burnt. What brand and model?
Stiletto
Hi All, my parent's Samsung UA48J5500 tv got bright spots in one area. Any idea ?
My LG TV has this problems too. Based on searching internet, LG TV glues on caps on LED backlight. After some time, the caps come off, and to solve the prob, have to glue it back.
oh god! thanks to this sub-forum
ok so recently my tv has this issue whereby i on the tv got sound but no display???
wtf ?
