ViewQwest Fiber Broadband Official Thread - Part 5
littleredboy
Seems like SK area still down zzzzzzzzz
They say rebates subject to approval.
Well, I aint paying for downtime.
jackycar
please update if you are able to get rebates? that would be a first for me in years of knowing VQ.
my VQ was down only for that few minutes. after that it went up again. did you try using Google DNS? seems that the bulk of people here having issues are using VQ DNS.
I'm also in SK btw
ZhuTou!
Mine never down before but im new to vq la about 1 mth
I use google dns all the way
I think vq dns not stable
Keep seeing ppl down here
Sent from Redmi 10X Pro using GAGT
jackycar
I'm using Google dns also, and never had an outage except the other day when everyone was down, I was down for like 2 or 3 mins.
Don't understand why ppl insist on using vq dns
littleredboy
I'm not an IT guy, duuno whats google dns or something.
They sent a technician down today, fixed stuff, had it going good then now down again.
littleredboy
I'm also in SK btw
They gave me rebates before as mine was down for 1 week.
They told me could be my problem.
I say send a technician down, if its my fault, i pay his labour fees.
End up the technician said its something on their backend, he cant fix it for me on-site. He had to call his guy to do something. Took quite long forgot.
1 week rebated.
jackycar
Just Google how to change your router dns to Google dns or cloudflare dns. Will take u at most 1 or 2 mins
Basically use google's dns u will have a lot less problem with outages and disconnection on VQ.
jackycar
1 week rebated.
Ya but if u didn't challenge them so confidently they won't do anything haha that's vq for u.
Most people not confident enough to say not their fault cause they not so pro haha
littleredboy
I just do simple remedy, on off modem router, restart computer, all the usual self remedy.
So i didnt believe it was my fault. But oh well seems like internet is fine now. Yes did the google dns thing. Didnt notice a difference but i'll see. Thanks anyway
jackycar
U won't notice a difference as there isn't one in speed.
But vq dns server always goes down frequently, thus u see all the outages here.
Wont get that with Google dns
ZhuTou!
Alot of user duno what is google dns including me
All the while im using MR, m1 etc, just setup router and good to go
Its only when i wanna switch to vq, start to read this thread then i know what is google dns
I think its quite common ba
Lesser ppl will read abt networking stuffs
giraffey
The problem with DNS servers offered by ISPs (this is across all ISPs globally) is that they can be slower, slower to refresh DNS records, less reliable and less secure. No matter what one's ISP is, I will always recommended to use 3rd party DNS.
ZhuTou!
Btw google dns need to set in router?
I set pc only for now
I using ap so i have 2 routers
giraffey
If set on the router, it means all devices connecting to the internet will use the DNS configured if these devices configure the DNS as automatically get from router. The DNS is normally configured on the main router.
If you set on the device such as PC, it will not take the DNS from the router, and will use the configured one.
littleredboy
Huh?
So setting dns on computer does nothing?
What about other programs using internet? Does the dns affect their speed?
jackycar
set at router level better i believe, then ALL your connected devices will auto use the Google DNS.
I just did a comparison between Google (8.8.8.8) and Cloudflare (1.1.1.1) dns. seems cloudflare ping is consistently lower (3ms vs 6ms).
https://imgur.com/gallery/38ynTLw
setting Cloudflare as default and Google as secondary now
jackycar
Huh?
set on computer is fine too, computer overwrites whatever is set at router level, but u set at router, if your computer is set to 'auto dns' it should follow the router setting too
