MIVEC525
- Feb 8, 2003
Haha nvm ba, just installed my second WS again and love the 2k screen.
U replace a new Whitestone?
still thinking whether to change to note 20 ultra from note 9.yesteday took photos then the display go haywire n turn very hot. but okay after a while.
just want to ask do we need change to 5G sim to get 5G network ? currently using 4G sim in my note 10+
thxNo need, all you need to do is to get 5G activated for your plan.
Note 20 Ultra voted best smartphone 2021 by consumerreports beating S21U! The actual consumerreports article is hidden behind a paywall, but here's a video:
i am using korea note20u and doesnt seem to haveActually what will be your usage scenarios.
If you are using it for gaming or using it to edit and export long video clip to YouTube then yes SD better. Or any use case that uses intensive cpu or gpu.
But if you are only using it for social media and content consumption or just social media taking photo and video, there is not much performance difference. Though so may say battery slightly lesser (after recent patch) comparing to SD but that’s is only slight not significant.
But that been said N20U (both SD / Enoxy) version battery life not that great.
As for photos taken some felt that SD photos better but YouTube had shown there is no noticeable difference in blind test plus if you are sharing over social media the compression algorithm totally mask whatever image advantage (if there is any).
So don’t buy base in SoC decision buy it base on use case.
Lastly overseas export set forth N20 seems to have country code / area code issue which requires workaround but no such issue with local set.
5G (though no use now) also is ok with local set and spotty with export set.
how about volte? is the set able to receive volte and without disappearing after a period of use?Can someone please help?
A friend of mine got a Note 20 5G Korean Snapdragon set after I recommended her "the reason why" SD vs Exynos but but she said only the numbers are showing and i feel its on me since i recommended. Names are NOT showing despite being saved and I know in this forum there is mentioned but not for korean phone.
I posted here in the hope that you guys who are more expert can advise on what to do.
The numbers simply do not show . Hope you guys can advise. Did search but can't find this issue to the Korea set.
Thank You.
do you have any idea on volte issues? i am using korea note20u with m1 telco. my volte keeps getting disabled after a period of use and triggered on after i restart my phone everytimeActually what will be your usage scenarios.
Hi, are you using HK or korea SD n20u set? i am using korea SD n20u set currently and can't get volte. Need some suggestions on how i can enable itM1 , VoLte work flawlessly since Day 1
Sent from Note 20 Ultra Snapdragon™ using GAGT
could you help me check if her korean SD n20u set has working volte as well? I am using M1 telco and my volte kept getting disabled after a period of use and can only be triggered back after phone restartCan someone please help?
Thank You.
The Note20 Ultra exihbits less blooming in the reds and is noticeably cooler hence the pictures look more balanced... but must check if the P40 Pro+ was in the right mode or not... I'm presuming both are in fully automatic mode...Can you guess correctly ?
P40PRO+ vs Note 20 Ultra
