Pocophone F3
ceestudent
Btw, the idle battery percentage is quite bad for my set.
Drain about 10-15% overnight. No email also since this is not my work phone. Hopefully they can give software update soon.
I also keep having auto mute now and then.
Skyy
OK folks. parcel is definitely coming today, status just changed to Parcel is being delivered by Courier, go check yours..
Skyy
Can use the xiaomi adb debloat tool. It is a GUI instead of command lines, more user friendly :s13:
agree. i used it previously for my m1 10.. pretty good.. can disable system apps and can reenable them back again, although some apps tend to revive itself after a reboot..
Skyy
whats the app that is taking up most of your batt? u can check from the batt stats right?
thunderskain
Hhmmm should have leh, here's mine:
How did u change your font?
KeYoKe
same... mine parcel is being delivered by courier... like finally :s22:
ya... so useful... i just uninstall though
WestGuy
Although i received my F3 early, other parcels which i bought through Shopee are going to be delivered today as well.
Looks like this batch of parcels was somehow delayed quite badly
Skyy
yeah, i check my mailbox everyday, last night came home my mailbox was full of my shopee and lazada stuff.. all came one shot..duno wtf happened with china/hk delivery sia..
ceestudent
First rank is lazada
Second is screen
Weird though, i only open lazada for a while to check my order status and close it after that. I only lock essential messaging apps like whatsapp and telegram
The ADB tool is download from github there? Let me try this weekend.
Actually i don't really obsessed with battery percentage to monitor the screen on time, etc. So long can leave about 30% or more at the end of the day is ok.
